Hey Ferrell75002,
I installed the same exhaust a while back. I remember mine smoked a little the first time I started the bike. I think it was just oil on the the new pipe.
Anyway, I did not have the benefit of installation instructions and ended up with a lot of extra fasteners. (Later, I got the instructions and I think I still would have ended up with a bunch of left over bits and pieces...it's like they just threw a whole bunch of stuff in the bag and leave it up to you to figure it out
A couple of days ago I noticed my back tire was barely rubbing on the pipe. Of course it only happens when the suspension is compressed. So, I started messing around with things to move the pipe out just a little. At first, I had the strap that surrounds the exhaust can attached to the exhaust hanger (the mounting bracket attached to the bike) by clamping the hanger in between the strap ends. Now I have the two ends of the strap located outboard of the hanger with a spacer in between and a bolt runs through the whole thing with a nut and a washer on the inboard side of the hanger.
Sorry I know my description might be confusing...I don't have any pictures...
First question to you (or anybody who has the same pipe): how did you arrange your exhaust can strap to exhaust hanger?
Secondly: Do you have or do you think you might have a rubbing problem?
An third: Did you have any left over parts like I did?
If anybody has any suggestions on this I'll really appreciate it!
