Clutch and engine case - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.com
Graves Motorsports
Old Apr 24th, 2009, 8:37 pm   #1 (permalink)
sick50ford's Avatar
I'm trying to get off the right side case cover and I'm stuck. Everything is loose and I broke the seal from case cover to block but it seems like the clutch basket is not permitting the removal.
Can someone who has removed the clutch or case cover confirm that the clutch assembly must be removed to slide cover off?
Is the 1" nut in the center of the clutch counterclockwise to unscrew?
any other helpful info will be appreciated
thank-Chris
this is where I'm at
Old Apr 24th, 2009, 8:58 pm   #2 (permalink)
You're definitely not getting the case off with the clutch still on there. I don't know if the nut is right or left hand thread, though.
2009 Aprilia RSV4 Factory (finally arrived)
2008 Red Hyper 1100S
2008 KTM 690 Duke
2007 Honda CBR600RR
colacin is offline   Reply With Quote
Old Apr 24th, 2009, 9:01 pm   #3 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Clutch hub and basket need to be removed. Much easier if you have a clutch hub holder tool and an impact. The big nut is righty tighty/lefty loosey.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old Apr 24th, 2009, 9:03 pm   #4 (permalink)
sick50ford's Avatar
thanks guys, that's what i thought.
i'll fire up the impact on it tomorrow
Old Apr 24th, 2009, 11:25 pm   #5 (permalink)
disgo duc's Avatar
Images: 23
remove clutch assembley and basket and should come off fairly easy.be carefull with removing sight glass comes off from front use rubber mallet and some kind of tooling that matches up to outside of seal around glass.take ur time so u dont break glass!
New Clutch, Decisions, Decisions ... Shazaam Hall of Wisdom 6 May 19th, 2011 9:00 am
Ducati Wet Clutch Cover Options???? daotoys1 Ducati Motorcycle Chat 1 Oct 4th, 2008 2:48 pm
Clutch Slips Only When Engine Cold... AlanS Sport Touring 2 Jan 2nd, 2008 9:25 pm
need help guys (clutch basket) ThePharaoh Ducati Motorcycle Chat 10 Jul 21st, 2007 5:47 pm
Will 916 clutch side engine case fit 900ss? andy900ss Supersport 3 Aug 14th, 2006 1:35 pm
