Hi Ducati Experts.
I got some weird problems with my 1100S hypermotard ´07.
After a paintjob and replacing the ECU i got problems.
I have bought a Ultimap U59 ECU for my hypermotard and now I have some problems on the dashboard.
It writes on the dash;
10.2 Horizontal cylinder coil, short circuit to ground. ?
11.2 Vertical cylinder coil, short circuit to ground. ?
34.0 PKUP. (I think this means low power on batterie)
37.1 IMMO. (Think this means immobilizer error)
After 20 secs. running in idle the RPM level meter in the dashboard disapeared! (Low batterie?)
Also the "exhaust valve regulator" say something but does not open when I gives it throttle? (Low batterie?)
Do I need to take this "exhaust valve regulator" off. So it stays open?
The Ultimap U59 ECU is race use, does this have something to do with it?
P.S. Ultimap does no longer have a website, so there is no support.
Hope 4 some experts.
Thanks.
