Front brake lever pull - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.com
Old Apr 11th, 2009, 12:05 am   #1 (permalink)
gerald29's Avatar
My front brakes work good on my 08 S, but I have almost an inch of lever pull before the brake engages. I cannot find an adjustment to fix that, just the one that moves the lever in or out (but does not affect play).
I took it to dealer to make sure there was nothing wrong. He bled them to make sure. He said the next step is to replace the lever assembly and cylinder (warranty).
Does anyone else feel too much extra lever pull before the front brake engages? Any suggestions?
Gerald
2008 Ducati Hypermotard S
2008 BMW 1200GS Adventure
2008 Husqvarna TE510
2006 Yamaha YZ450F
2007 Beta Rev3 250
IBA, TORCS, AMA
gerald29 is offline   Reply With Quote
Old Apr 11th, 2009, 3:17 am   #2 (permalink)
Mati-O's Avatar
if you got the stock brake lever the plunger inside is uselesssss its a egg. if you can find a spare 749/999 lever with a plunger like your clutch side it will work try 58cycle.com for 18 bucks. u can adjust it any way u want.
08 Hypermotard 2-1 termi, DP race seat, CC pressure Plate, Speedy Moto flow clutch cover. Rizoma Logic mirrors/ turn signals.
06 749 Biposto- Traded for above. I'll miss u bit#ch.
Mati-O is offline   Reply With Quote
Old Apr 11th, 2009, 7:31 am   #3 (permalink)
Move to Brembos?
Mine, too. First 1/2 inch is soft, then, wham, lots of brakes. I can modulate it to deal, but yes, same problem. Also bled brakes & didn't help. Local, knowledgeable bike shop commented that the Duc stock brake lever/master cylinder is crap. I installed a great Brembo lever / cylinder on an R1200S a couple of years ago & WOW that helped.
Now thinking of doing the same thing for the Hyper. Just a little $400 fix.
Petethepup is offline   Reply With Quote
Old Apr 12th, 2009, 7:59 am   #4 (permalink)
sconly's Avatar
just and fyi, this topic has been well covered in the past, you do not need to purchase additional parts to resolve this issue, you should never try to resolve a problem by throwing money at it.
http://www.nedr.org/forums/index.php?showtopic=402
sconly
www.NEDR.org for riders by riders
sconly is offline   Reply With Quote
Old Apr 14th, 2009, 8:06 am   #5 (permalink)
snow's Avatar
Images: 24
linky dont work....
Mine has the same issue....
floridasportbikers
2009 Hyper S GONE
2009 848
2011 1198SP
snow is offline   Reply With Quote
Old Apr 14th, 2009, 8:27 am   #6 (permalink)
sconly's Avatar
try this http://www.nedr.org/forums/brembo_monobloc_fix
sconly
Old Apr 14th, 2009, 2:18 pm   #7 (permalink)
snow's Avatar
Images: 24
that worked great DIY
floridasportbikers
2009 Hyper S GONE
2009 848
2011 1198SP
Old Apr 14th, 2009, 3:15 pm   #8 (permalink)
Brainfry's Avatar
Did it do anything to help with the front brake "moan/squeal"... really annoying every time I stop. Or is that more of a pad issue?
b
Never enough garage space.
'05 BMW K1200LT
'07 BMW R1200GS Adventure
'08 Ducati Hypermotard S
'10 BMW S1000RR
Brainfry is offline   Reply With Quote
One Way to Lower the Brake Lever a LOT GOTJ Sport Touring 3 Mar 9th, 2009 6:24 pm
Front Brake Lever parts Needed leeg427 Multistrada 0 Aug 14th, 2008 1:30 am
front brake leaking brake fluid? kurtfriedrich Superbikes 2 Mar 19th, 2007 1:19 am
