Question about wiring... - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearMotorcycle.com
Old Apr 10th, 2009, 11:54 pm   #1 (permalink)
So... I am pretty useless when it comes to working on anything that has wheels. I can take it apart and put it back together but that doesn't mean I have any idea what I am doing... Then there is electronics... I got nothing.
I am trying to wire up my radar detector but I honestly have no clue where a good place to connect it would be. I did find some How-tos but nothing for the hypermotard and nothing showing exactly how it is wired up.
That is what I am looking at. What do I do... Short of taking it to the dealer :-P
Thanks,
Bryant
swanny338 is offline   Reply With Quote
Old Apr 11th, 2009, 9:47 am   #2 (permalink)
Werloc's Avatar
Images: 6
People still use those?
Werloc is offline   Reply With Quote
Old Apr 11th, 2009, 10:02 am   #3 (permalink)
GMP
Directly off the battery with an inline fuse is easiest and safest if your not comfortable tracing out a switched circuit. Detectors don't need switched power anyway. That said, if your running a DP ECU and no O2 sensor, you can pick up switched +12V on the O2 sensor connector. I wired my GPS this way.
What you have to be carefull of with a CAN bus system is tapping into a source that is switched by the ECU.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Apr 11th, 2009, 10:04 am   #4 (permalink)
reitsmjo's Avatar
You really have two choices, 1) wire it directly to the battery which is under the seat in the rear. You could follow some of the existing wiring and use the rubber cable ties to keep it nicely in place and then up the front to the handlebars and follow the handlebar wiring to the mount for the detector. Make sure you include an inline fuse rated for your detector in the positive side of the circuit. This option is always on so make sure you turn off the detector when not in use.
2) You could use the available plug for the grip heaters. It should be in the front of the bike under the fairings. It will have two wires into it and the plug is covered by a protector cap. You can buy the male side of the plug from
http://www.ducatidesigns.com/. You won't need to wire a fuse in this option as there is a 5 amp fuse already in the fuse box for this connector. Make sure that you confirm you have the right connector by popping the fuse then testing the connector pins with a multimetre. This option is nice because it is already fused and it only works with the key turned on. However, if you plan to put on heated grips sometime then don't use this option.
You could get into more complex addition of keyed conncector blocks with a relay but I don't think it is required for this application.
___________________________________________
2008 HM 1100S
2007 MTS 1100
reitsmjo is offline   Reply With Quote
Old Apr 11th, 2009, 9:02 pm   #5 (permalink)
Caidly's Avatar
Really?
if you need to know... ask...
Old Apr 11th, 2009, 9:57 pm   #6 (permalink)
hyperdookie's Avatar
Images: 9
Originally Posted by CTarna View Post
Really?
There is a plug next to the diagnostic plug under the right tank fairing.I was going to use it to power the VDST without having to pull the seat, so I purchased the plug kit from ducatidesigns months ago.That being said, I have been too lazy to hook it up.
Auxilliary Power Connector Kit
Price: $20.00
Tap into unused 12V power for accessories on your 2004+ ST or Multistrada
Old Apr 11th, 2009, 10:42 pm   #7 (permalink)
AXE
AXE's Avatar
I recommend this cord, depending upon what unit you are running.
http://www.motorcycleradar.com/produ...htm#DirectWire
The only way to run is with a detector hard wired into the bike to an ignition hot wire. There options to hard wire in the detector to one of the ignition hot wires near the fuse block under the seat. Check it with a multimeter and you are good to go. Like was stated, it is easy to route the wire up to the bars using the existing wiring harness path.
I highly recommend the new Passport 9500Xi, with GPS capbilties for anyone with known speedtraps or photo radar/red light cameras.
I also recommend the Techmount bar risers. You can get the package deal here.
http://www.motorcycleradar.com/produ...dar%20Screamer
I also highly recommend custom molded earplugs like this so you can hear the damn thing. They are great for cutting wind noise too and I listen to my Sirius Stilletto wherever I roam.
http://www.earinc.com/p2-iplugz.php
Here is the setup I have on the Hyper.
Radar Detector Pictures
Out!
2008 Ducati Hypermotard
Old Apr 11th, 2009, 10:57 pm   #8 (permalink)
unfast1's Avatar
Out!
How do you here the detector? I have the same one. Are you using the headphone jack?
2008 Black Hyper S
2005 CBR 1000RR
2001 CBR 929RR
1997 GSXR 600
unfast1 is offline   Reply With Quote
Old Apr 11th, 2009, 11:00 pm   #9 (permalink)
http://www.motorcycleradar.com/dircord2c.jpg
That is the cord I have for my Passport 8500
I also purchased a Techmount and some nice earplug's.
I just have no idea how to wire it up. Though with the information here I think I can figure it out.
Thanks for the help. I appreciate it.
Old Apr 12th, 2009, 6:01 am   #10 (permalink)
reitsmjo's Avatar
Really?
I stand corrected. Heater plug only on my Multistrada. So that option is out, unless you trade it for a multi.
2008 HM 1100S
2007 MTS 1100
99 FI wiring question? ecannon1 Supersport 10 Mar 4th, 2009 10:15 pm
748 Wiring Harness/ECU Question gcardamone Superbikes 11 Jan 22nd, 2009 11:02 pm
Wiring question cruisincruzan Sport Classic 7 Feb 2nd, 2008 9:32 pm
Wiring question fester Supersport 0 Jan 15th, 2007 6:05 am
