Front sprocket 14T prob. - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Apr 10th, 2009, 12:52 pm   #1 (permalink)
Hi guys, I recently made a lot of changes into my hyper all in once. One of them was to change the front sprocket from 15teeth to 14 teeth as it supposed to add low end agression.
I am not an expert on bikes I have to admit it. I also changed the rear sprocket from stock to a dp ergal. Now, after driving it I feel no added agression whatsoever!!!
A friend of mine has made the same change and it feels total different. Is there anyway that the mechanic actually did not make the change???
If so, is there any way to test this without striping down the necessary parts to findout??
TIA
George
HyPeR MaNiAc 08
george_v is offline   Reply With Quote
Old Apr 10th, 2009, 1:02 pm   #2 (permalink)
It's pretty easy to remove the sprocket cover, and a couple other parts so you can just count the teeth.
It's not going to make a huge difference overall, but you should notice it's easier to lug the engine at slow speeds in 2nd gear with the 14T sprocket...
Old Apr 10th, 2009, 1:30 pm   #3 (permalink)
Thanks for the answer as i said I am not an expert so sorry if my question was a bit stupid...
George v
HyPeR MaNiAc 08
Old Apr 10th, 2009, 1:31 pm   #4 (permalink)
Brainfry's Avatar
Yep... you should definitely notice a difference... not to mention how much quicker you'll have to be shifting.
b
Never enough garage space.
'05 BMW K1200LT
'07 BMW R1200GS Adventure
'08 Ducati Hypermotard S
'10 BMW S1000RR
Brainfry is offline   Reply With Quote
Old Apr 10th, 2009, 5:22 pm   #5 (permalink)
14
Had 1 put on big difference, and yes you shift a lot but I ride a go-kart like mountain road.
ktm31 is offline   Reply With Quote
Suspension cheat sheet or best literature to bring to track with me? Dana Superbikes 5 Oct 13th, 2010 6:45 pm
Question for 696 owners with 14t front sprocket Blackout Monster 0 Oct 13th, 2008 1:31 am
14T Sprocket Installed today...quick question mdesmond Sport Classic 8 Aug 8th, 2008 4:10 pm
14T Front sprocket MDMason HyperMotard 23 May 10th, 2008 3:23 am
