Fix the Bad Shifting and False Neutrals - Factory Pro - Ducati.ms - The Ultimate Ducati Forum
post #1 of 21 (permalink) Old Sep 6th, 2016, 8:40 pm Thread Starter
Although my machine is still at the dealer awaiting the arrival of the Termi kit, I have been doing a ton of research as to what will probably need fixing when I do finally get the bike.
One of the first things I noticed as a very common complaint was the poor action of the shifting mechanism i.e.: stiff, unable to locate neutral, missed shifts, and false neutrals. Figured I'd start by getting this addressed first.
I have had excellent experiences with the Factory Pro Roller Bearing Detent Arm, Spring and Shift Stars on other bikes...soooo, I went off to Factory Pro to take a look around....I didn't find anything specific to the 939SP, so I fired off an email to the guy behind Factory Pro, Marc Salvisberg.....lo and behold, there is a kit.
The kit for the 11 degree Testastretta engines in the Hypermotard and the Hyperstrada is Part Number SHFT-PRO-D748-M821-CER. although the kit doesn't come with a new shift star, it does come with a new spring and detent arm with a ceramic bearing.
I will be installing this kit in the very near future.......If you hate the shifting of your Hyper....you might wanna look into this kit.
http://www.factorypro.com/
AZBoy is offline
post #2 of 21 (permalink) Old Sep 6th, 2016, 9:26 pm
I'm sure the kit is high quality, but I must say my hyper gearbox is the best of any bike I've ridden. It took about 2,000 miles to wear in, and it has been flawless ever since. How many miles on your 939?
appliance57 and Svet Angelov like this.
kuksul08 is offline
post #3 of 21 (permalink) Old Sep 6th, 2016, 11:10 pm
unM0derator
RedST's Avatar
Images: 3
My experience has been that all Ducs have the symptoms you mention when the shifter linkage rod is not properly adjusted. Every Ducati I've ever owned had to be adjusted in this way after I acquired it. Just like setting up your suspension.
A five minute job that will address most of these issues.
Geoff
Current pastimes: 2004 ST4s / 2010 SF 1098 S
RedST is offline
post #4 of 21 (permalink) Old Sep 7th, 2016, 10:09 am
Sarge's Avatar
Geoff
So, what did you do to adjust it? What is the magic process here?
Sarge is offline
post #5 of 21 (permalink) Old Sep 7th, 2016, 3:31 pm
unM0derator
RedST's Avatar
Images: 3
If you have a normal pattern shifter (as opposed to a reverse pattern), you want the effort for up and downshifts to be equal, so lengthen the linkage rod if you feel upshift is not engaging as desired or shorten for downshift quality. Once you have a good balance, neutral should be easier to find. If not, that may also suggest you investigate clutch throwout stroke and clutch pack height on dry clutch models. Probably not much else to check on a wet clutch.
Looking at how little room there is on the 939, I'm wondering if foot placement and throw length contribute to people's description of poor feel.
Geoff
RedST is offline
post #6 of 21 (permalink) Old Sep 7th, 2016, 9:13 pm
How to improve shifting on hyper 939SP
Fellow 939'er, some tips for you (some obvious, others less so):
1) Breaking on these bikes and the gearbox is a little longer then one might expect. 4000 km or 2500 miles is not unrealistic before you get everything settled and it works the way it's supposed to.
2) It goes without saying that if you are sissy shifting or if you are not wearing a racing boot with a stiff sole, the likelihood of missed shifts and false neutrals is much higher.
3) Because this bike runs a wet clutch and the gearbox is bathed in motor oil, the type of oil used will actually make a difference in responsiveness of the shifter. I have experimented with several different brands of oil, several different viscosities and I find that the Motul 7100 in 10w-40 delivers great results.
4) Shifter adjustment aside, replacing the foot pegs can also provide a more positive shift feeling. See my recent post about the Ducati performance foot pegs mod for details. Made shifting even more responsive for me.
It's obviously a matter of personal preference but I can tell you from first-hand experience that the bike shifts very well with the above conditions respected and obviously once warmed up (another quirk with wet clutch Ducs -shift way smoother when up to operating temp). I can get through a full day ride or track day without missing a shift or hitting a false neutral.
All that said, I'd be real curious to hear what your experience is like if you do the Factory Pro mod...
Chancemoto.com | 2010 Ducati Streetfighter 1098 | 2016 Hypermotard 939 SP | 2016 KTM 500 EXC / SuMo
DJKham is offline
post #7 of 21 (permalink) Old Sep 7th, 2016, 10:03 pm Thread Starter
I will definitely let everyone know, once it's done. I have used these on multiple bikes and the shifting becomes a "think about it, and it's in gear" situation. No special witchcraft, no fiddling around, no experimentation with different oil, they just flat out work.
I have to put some miles on it first....then it will go in for tuning and the installation of the kit will get done following that process. Still debating on an add on EFI controller, or something else.
AZBoy is offline
post #8 of 21 (permalink) Old Sep 8th, 2016, 12:09 am
unM0derator
RedST's Avatar
Images: 3
Very likely that mod would feel much better. That short linkage has less effective ratio in the knuckle than the standard 10-14cm linkage and shifter on most Ducs. A shifter with a larger radius for the knuckle would also work.
.02
Geoff
DJKham likes this.
RedST is offline
post #9 of 21 (permalink) Old Sep 8th, 2016, 8:31 am
Images: 4
Going from a 2v SS to a Testastretta S4rs I can only say the shifting was a lot better, in fact, one of the best shifting bikes I've owned. I don't recall ever missing a shift. Adjust your shifter, wear boots that don't flex.
duc96cr is offline
post #10 of 21 (permalink) Old Oct 4th, 2016, 12:14 pm
On my 821, I can't get into neutral while at a stoplight, it's either 1 or 2. While rolling though, it'll go into Neutral just fine.
Same thing when upshifting, false neutrals between 4-5 for some reason, most annoying thing I have ever experienced and scary too.
2016 BMW S1000RR | 2015 Ducati Hypermotard (Sold) | 2014 BMW S1000RR (Stolen) | 2006 Honda CBR600RR (Sold)
redtwo is offline
Human Verification
