Oil leak under the belt cover - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearGraves MotorsportsMotorcycle.com Classifieds!
SportbikeTrackGear
Old Mar 28th, 2009, 6:40 am   #1 (permalink)
Greetings all,
I parked the hyper last evening after an hour ride and when I hopped off the bike I noticed a puff of smoke. After a brief inspection, I noticed oil dripping out from the horizontal cylinder belt cover.
The bike has 621 miles and I already scheduled the 600 mile service. My local dealer and Ducati seem to be stand up folks, so I am not terribly worried.
My question is, has anyone experienced this? Is this just a cam drive gear seal leak? It would seem to me that the repair would require pulling the cams belts and gears at a minimum and possibly the heads.
I would assume a leak will require the belts to be changed as well.
Is there any other components of the repair that I should request as part of the work. If the work requires pulling the heads, I may ask to have the race cam and ECU installed on my dime.
Is this a known issue as a quick search of the threads did not show any obvious threads on this....
Best regards,
Joe
BigJoe is offline   Reply With Quote
xx9 series : secret to removing vertical belt cover? betarace Superbikes 19 Jun 7th, 2011 7:46 pm
Oil leak, crimped grommets, used bike stuff apehair Supersport 5 Jan 13th, 2009 8:46 am
Oil Leak! cgociferS4R Monster 2 Dec 14th, 2008 8:04 pm
Oil cooler leak fastphil Superbikes 11 Oct 15th, 2008 8:11 am
cam belt rubbing on cover kevin-93-750ss Supersport 4 Apr 21st, 2007 1:03 am
