stock air box mod - Ducati.ms - The Ultimate Ducati Forum
Old Mar 24th, 2009, 7:27 pm   #1 (permalink)
disgo duc's Avatar
Images: 23
stock air box mod
with doing the airbox mod to stock lid does motor have to be tuned again ecu etc...i already have motor tuned for a full zard system.
Old Mar 24th, 2009, 10:41 pm   #2 (permalink)
08hyper's Avatar
Maybe, depends on what ECU your using, if your running the stock ECU with NO device like the Power Commander, I would not open the airbox
up, the bike will run too lean, but if have an DP performance ECU by all means open it up, top & bottom, you'll gain 4 to 5 HP! but you might have to have the TPS reset. Aloha Alex
Old Mar 24th, 2009, 11:01 pm   #3 (permalink)
Monstaman's Avatar
You won't need to reset the TPS but if you have the DP ECU then yeap definitely fuel it up accordingly or as Alex said it will run too lean.
If you don't have the DP ECU you are pretty much cornered into doing nothing except maybe an O2 manipulator.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Mar 25th, 2009, 12:16 am   #4 (permalink)
disgo duc's Avatar
Images: 23
have stock ecu and no power commander can i use stock ecu with power commander or do ineed both?on the zard system i was told u dont need the ecu so i didnt get one so i guess if i want to open it get ecu and commander.
Old Mar 25th, 2009, 12:20 am   #5 (permalink)
disgo duc's Avatar
Images: 23
what is the 02 manipulater does it trick the ecu to think it still has one?
Old Mar 25th, 2009, 12:39 am   #6 (permalink)
Monstaman's Avatar
You can vary the signal to the ECU, basically it tells lies to the ECU and it adjusts the fuel accordingly.
You could do the top of the box hole pretty safely down that track but if you wanted to go K&N etc then an ECU is strongly advised.
You can't run a PC111 with the stock ECU as the stock ECU runs closed loop, the DP ECU allows it to run open loop and accordingly the PC111.
Hope this is all clear.
Cheers KTiMpostor
Monstaman
Old Mar 25th, 2009, 1:13 am   #7 (permalink)
disgo duc's Avatar
Images: 23
gotcha monstaman thanx for ya input cleared things up for me!
Old Mar 25th, 2009, 1:36 am   #8 (permalink)
Monstaman's Avatar
Sweetas mate
Cheers KTiMpostor
Monstaman
Old Mar 25th, 2009, 3:35 am   #9 (permalink)
freezer16801's Avatar
this is the most expensive bike I've ever owned to work on. My last bike (TLR), you could reflash the ECU for free, and you could do the TPS and TB sync yourself.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Mar 25th, 2009, 2:06 pm   #10 (permalink)
disgo duc's Avatar
Images: 23
tell me about it!$$$ i love it to death though,unlike my ex wife
CF Race Air box, Runners and Nemesis ECU: 749-999 moto Motowheels 0 Dec 5th, 2008 8:31 pm
ST4s - Aribox mod Ascalon Sport Touring 7 Sep 19th, 2008 9:16 pm
Air filter and box mods kirk Supersport 7 Jun 19th, 2008 10:45 pm
Air filter box - Help! HalaHyper HyperMotard 4 Mar 21st, 2008 10:18 am
