Originally Posted by dukepilot
If you're set on not buying a DP ECU, you have a few options. You can try the the fatduc emulator that allows you to make adjustments to the closed loop operation of the ECU by manipulating the signal from the 02 sensor. If you mod the intake along with the exhaust your fueling may still be lean however.
With the stock ECU the Power commander will only act on the open loop operation above around 20% throttle/4400 rpm. This does not seem to me to be an ideal setup.
I'm using a FatDuc with a PC III and the closed- to open-loop transition is really
seamless. Fuel metering on this setup is about perfect for rideability, with no
hesitations, flat spots, or lean surges anywhere. The tendency for RPM to
drop (or stall) near idle when hot is gone now, too. Operating temps are
down as well, and while I expected a hit in fuel consumption, my fuel range
compared to stock has been about the same. There are times when closed-
loop operation is actually _better_ for part throttle conditions, especially if
AFR targets are reasonable, not necessarily Euro-3 compliant.
While it sure would be great if these bikes were optimized for performance
and rideability from the factory, emissions compliance being what it is, we
can only resort to after-purchase re-programming and devices like O2 sensor
manipulators. This is only going to get worse in the future, with movement
toward more and more tamper proof fuel systems. Even though it costs us
riders, both in time and money, at least we still have options to "get it right"
for now... options that might well disappear if governments have their way
with it. Sorry, just getting on my libertarian soapbox... think I need my
power wheelie fix.
