Questions about track day setup for Hyper - Ducati.ms - The Ultimate Ducati Forum
Old Feb 24th, 2009, 9:42 am   #1 (permalink)
I'm trying to plan the first track day on my Hyper, and had a few questions about getting the bike ready. Do you guys usually remove your side mirrors completely, or just tape them closed? Does anyone know if it's possible to turn off the headlamp through one of the service menus, or some other way? I know the headlamp gets pretty hot and I really don't want to tape over it while it's on, and I was wondering if there's another solution other than pulling the bulb or the fuse.
I've got my suspension setup dialed in perfectly for moderately aggressive street riding, and really don't think I'll need to change that. Any other suggestions on prepping the bike for the track would be appreciated.
2011 Multistrada 1200S
2009 BMW HP2 Sport
1998 900SS/FE #118
1993 900SS
Old Feb 24th, 2009, 10:06 am   #2 (permalink)
Banned
I'd remove the mirrors and pull the fuse for the headlight and taillight.
Old Feb 24th, 2009, 10:26 am   #3 (permalink)
piarjr's Avatar
Cool
I remove the mirros, unplug the connectors for the tail light and blinkers, remove the tag and blinkers(take tag holder out), on the headlight, a remove the fuse and I already have my headlight covered with perforated vinyl, tape front blinkers, taillight and wheel weights...done
piarjr is offline   Reply With Quote
Old Feb 24th, 2009, 10:55 am   #4 (permalink)
sick50ford's Avatar
sound requirements and tie wired parts may apply at certain tracks
Old Feb 24th, 2009, 5:01 pm   #5 (permalink)
hyprduc's Avatar
Different tracks require different things. Normally I remove the tail light and remove the license plate/turnsignals completely. I pull the connector on the headlight and tuck it into the frame. Tape over the headlight. Remove the mirrors completely and tape over the turn signal lenses. Tape the wheel weights. Recently I also had to safety wire the oil drain plug, oil filter, and oil filler cap. I used a hose clamp on the oil filter and drilled at a 45 degree angle from the bottom of the drain plug into the center with a 1/16" drill bit. Then wired them. It was quick and easy. The whole prep takes less than one hour. If you're running the Corsa III's you should consult a tire guy at the track for pressures. At Laguna Seca (fast track) I was told by Pirelli to run 31psi front and 30psi rear. I normally run approx 33psi on both ends for the track and 34psi for the street.
Hope this helps!
hyprduc is offline   Reply With Quote
Old Feb 24th, 2009, 5:24 pm   #6 (permalink)
Caidly's Avatar
Here is an AMA Tech Form:
http://www.mediafire.com/?sharekey=3...f4342308ea0787
Use as a reference.
if you need to know... ask...
Old Feb 24th, 2009, 5:36 pm   #7 (permalink)
Banned
HA! That's a good start but still funny Definitely as good a list for a trackday as anything.
I'll have to revise it if we run that race again, the release at the bottom is way messed up.
Old Feb 24th, 2009, 7:13 pm   #8 (permalink)
infidel's Avatar
Just keep an eye on your compression. Even if you have set up your bike for aggressive street riding, you will brake harder on the track than on the road so the front dives a bit more. If your compression is too soft the front will dive, take weight of the rear and you'll lock up the rear very easily. Ask me how i know!
Hypermotard 1100S
Aprilia SXV550
Aprilia RS250
Suzuki RGV250
Old Feb 24th, 2009, 7:31 pm   #9 (permalink)
08hyper's Avatar
Hope this helps!
+1 yeah what he said! Aloha Alex
but 30/30 for the Bridgestones BTO16's (track only)
Old Feb 25th, 2009, 8:50 pm   #10 (permalink)
freezer16801's Avatar
don't forget to swap out your coolant for water! lol.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Oct 20 Buttonwillow Track Day - Be There!! hyprduc HyperMotard 31 Oct 21st, 2008 12:55 pm
So Cal track day, let's bring some HDD to Fontana! EarthBM HyperMotard 6 Sep 27th, 2008 5:51 pm
Assen Track Day Report bruntr Ducati Motorcycle Chat 2 May 26th, 2008 7:04 pm
Road America Track Day Report kentamcolin Sport Touring 9 Aug 16th, 2006 12:41 pm
