Oil leak from front valve cover - Ducati.ms - The Ultimate Ducati Forum
Old Feb 23rd, 2009, 9:39 am   #1 (permalink)
I noticed a little oil weeping from the valve cover area of my front cylinder a few months back, and just applied a little more torque to those bolts and thought it was fine. I haven't ridden the bike in a number of weeks (I'm in the honeymoon stage with the 1098!) and yesterday I was poking around in the garage and noticed a bit of oil on the floor under the front cylinder. It's not much, so I checked the valve cover bolts again and a couple could be turned a quarter-turn without much effort, so I did that. Anyone else have any seeping from the front valve cover? Does anyone know the torque setting for the valve cover bolts?
2011 Multistrada 1200S
2009 BMW HP2 Sport
1998 900SS/FE #118
1993 900SS
Old Feb 23rd, 2009, 9:55 am   #2 (permalink)
IainMac's Avatar
They aren't big bolts so dont over tighten them or they'll likely strip the threads.
Get some thread lock (not the permanent stuff) and take it apart. clean the threads/bolts and refit with the threadlock. Can't recall the torque specs off hand but this chart gives some indicators and they arent high.
http://www.imperialinc.com/pdf/A_Fas...rqueCharts.pdf
900sl 95-97; 916 97-02;1000ss 05-06; 999 06-07;900sl(94my) 07-, PS1000le 07-09, 888 Strada (94my) 08-, XTZ660 Tenere 09-
IainMac is offline   Reply With Quote
Old Feb 23rd, 2009, 11:22 am   #3 (permalink)
sick50ford's Avatar
Torque specs-hyper
Hyper torque specs
Old Feb 23rd, 2009, 5:20 pm   #4 (permalink)
NYSport's Avatar
Images: 4
Complete Torque Settings- Hypermotard
Here is a link to all Hypermotard torque settings. They are in NM and need conversion, second url.
http://www.ctarna.com/Ducati/HyperMo...20Settings.pdf
http://www.pitt.edu/~rsup/touqueconv.html
Old Feb 23rd, 2009, 8:54 pm   #5 (permalink)
bullet3z's Avatar
I would contact the dealer and has this fixed under warranty. It might be a bad gasket.
bullet3z is offline   Reply With Quote
Old Feb 23rd, 2009, 9:23 pm   #6 (permalink)
Monstaman's Avatar
Mine have done the same, quick re-torque sorts it out, I had to do the cam end O ring as Luigi nipped a bit off when he installed it hence it leaked.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Oil Leak! cgociferS4R Monster 2 Dec 14th, 2008 8:04 pm
Oil cooler leak fastphil Superbikes 11 Oct 15th, 2008 8:11 am
03 999 coolant leak from water pump cover gasket?? please help!! brian777 Superbikes 3 Jul 31st, 2006 1:05 pm
Front Exhaust leaking oil after valve adjust juicersr Supersport 13 Apr 22nd, 2006 7:55 pm
