Feb 8th, 2009, 11:32 am
DP cam ECU question
I have decided to go with the Quat-D 2 into 1 exhaust. If I buy the DP cam kit does the ECU work for this?
Here is the description on the the CAm/ECU from Pro Italia-
This is a set of racing camshafts with new profiles to optimize engine performance at medium-to-high rpm of your Ducati Hypermotard. The kit comes with an ECU that is calibrated for use with these camshafts and with the addition of a separate item, the complete racing exhaust system.
What is the separete item needed to calibrate for the full exhaust or are they stating that the full exhaust is separate?
Feb 8th, 2009, 11:33 am
Also do you guys think that if i self install the cams it would void the warranty? Of course done correctly?
Feb 8th, 2009, 12:11 pm
seems that the separate item PI mentions would be the DP full exhaust system (the termi 2-1), as that system is mentioned in the DP accessories book in the section on the DP cams/ECU kit.
you will need to take the bike to a dealer, or find someone local to you that has the VSDTS, so the TPS can be reset when you install the ECU.
on the cams install, as these are DP parts, if you have them installed to specifications by someone besides a ducati dealer, your warranty (at least here in california, where i know the specific law) will NOT be voided.
a presto,
johnc
Feb 8th, 2009, 6:18 pm
Double positive...
Yes.
Duc dealers may have special Ducati tools to do this, or may use Technoresearch equipment. If you wish you can purchase the Technoresearch VDST yourself to do your own final tweaking, etc. at home...
http://www.technoresearch.com/
http://www.technoresearch.com/Produc...DSTS-Motorbike
Have fun!
Dallara
psychiatrist's office
Feb 8th, 2009, 9:14 pm
Triple positive! a lot of us are using the cams ECU with an aftermarket exhaust
& airbox mod, it was the cheapest way to get a DP performance ECU, and you
have the option to put in the cams later if you want, and using the DP ECU &
cams will not void your warrantee, as long as the Ducati shop installs it. Aloha Alex
Feb 9th, 2009, 8:11 am
Which ECU comes with the cam?
if you need to know... ask...
Feb 9th, 2009, 12:46 pm
Cams ECU
DP part# 96519208B 18% more fuel than stock, No O2 sensor, changes FI to a "open loop" system. Aloha Alex
Feb 9th, 2009, 1:19 pm
Thanks. I just picked up the 708B. Making sure I got the right one.
