Bored this afternoon, made my own tail-tidy - Ducati.ms - The Ultimate Ducati Forum
Old Feb 7th, 2009, 8:02 pm   #1 (permalink)
So i'm in the garage looking at the bike and that long protrusion hanging off the arse end, who's only purpose in life is to hold your license plate, was really offending my eyes. out come the allen wrenches and a socket set. yanked it all off. cut down the steel bracket that mounts the whole shebang and drilled a hole to mount a license plate holder that i had laying around.
took me maybe an hour and a half, used an angle grinder to make the chop, a little black paint and hoo-dog, does it look better. plate mounts high, right below the taillamp, so for now i disconnected my plate lamp. i'll post some pics if anyone is interested in trying something similar. too lazy to walk down to the garage right now.
kyle
kyle_01 is offline   Reply With Quote
Old Feb 7th, 2009, 9:00 pm   #2 (permalink)
sick50ford's Avatar
i'm with you i don't know about them crazys here that would spend 100 bucks on something so simple. sounds like i did something similar but for my top two plate bolts i used L.e.d. bolt/studs to make it all legal.
Old Feb 7th, 2009, 9:19 pm   #3 (permalink)
freezer16801's Avatar
I'd definately would like to see your work. I was looking at the donkey dick hanging off the rear the other day too, and thought, "there's something that I gotta be able to do to that."
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Feb 8th, 2009, 1:12 am   #4 (permalink)
sick50ford's Avatar
here is what i did, my blinkers are on the plate frame but you could easily add indicator mounting tabs to the side of the plate bracket. i cut down the stock steel bracket just behind the rear holes then fabbed up a plate mount with the top holes using the light/bolts.
while redoing the tail section this yesterday, i cut up the original concept and added more angle to the plate.also shown is one of the led studs
Old Feb 8th, 2009, 9:14 am   #5 (permalink)
that looks really clean! i'm gonna run to the garage and snap a few pics. i can see why you needed to add the plate lamp, yours is mounted a lot lower than mine. i've got a single rear can on my exhaust, so it changes the mounting options quite a bit. that looks really good though, you'll see i left the stock signals on for now, i have some smaller units i was thinking of adding. we'll see.
Old Feb 8th, 2009, 9:40 am   #6 (permalink)
i'll cut off the turn signal brackets that are on the plate bracket and add some type of plate frame to keep my plate in one piece. i just bolted this together out of what was laying around in the garage. as you can see, i'm so close to the tail lamp that it will serve just fine as my plate light. we'll see how that goes...
Old Feb 8th, 2009, 9:45 am   #7 (permalink)
forgot to add, as a bonus- with the termi 2-1 it reveals a pretty bad looking gap in the panels that mount under the seat (where they meet above the tail lamp) mounting the plate up high covers it up. i do have the new carbon fiber replacements on order, so i'm not sure if they will line up any better than the plastic ones. i'm going to add a little more angle to the plate too, it's almost vertical now. once you chop the junk off of the back, it's really easy to come up with lots of different solutions for mounting the plate.
Old Feb 8th, 2009, 10:32 am   #8 (permalink)
bullet3z's Avatar
kyle, how were you able to mount the turn signals up so high? Did they just bolt on or did you have to make a bracket for them to mount up?
Last weekend at the IMS in Cleveland they had the Ducati display. 1 of the 2 Hypers had the DP LED signals mounted the same way yours are but they were using a bracket to mount them. It looked really good with the small LED signals mounted up there.
bullet3z is offline   Reply With Quote
Old Feb 8th, 2009, 11:40 am   #9 (permalink)
08hyper's Avatar
Exclamation
Chris, looks good! just make sure that there is clearance between the tire & plate, when "bottomed" out, a few forum members have wadded up their plate when the tire made contact. Aloha Alex
Old Feb 8th, 2009, 11:57 am   #10 (permalink)
i think they must mount that way when you get the termi 2-1. mine have a bracket built into the rear piece of bodywork. i have some smaller led units i'm going to bolt up when i find the energy. for now, i'm just happy to have the ass end down to it's bare minimum. the bike is so naked, i think that getting the mess off of it's butt is a huge improvement!
LED indicators, evotech tail tidy jpgibson HyperMotard 4 Dec 29th, 2008 1:30 pm
WASP Tail Chop! Ducatibomber Sport Classic 8 Aug 13th, 2008 10:32 am
Matts Tail Chop Part 2 - The Finally Stealth Tail! mattgregg Sport Classic 5 Jan 14th, 2008 9:51 pm
