Gutting stock exhaust?? - Ducati.ms - The Ultimate Ducati Forum
Old Feb 2nd, 2009, 11:28 pm   #1 (permalink)
JTinFL's Avatar
I know its probably been mentioned before but who hear has gutted there stock exhaust and how were the results?? In my shop while another Hyp was being fitted with a slip-on,I was suprised the stock main pipe wasn't that heavy. I'm sure most of the weight comes from the overly restrictive baffles. I personaly like the look of the stock system and being employed at a Ducati shop will probably purchace the ducati performance mid pipe and ECU if the stocker can be gutted. Any info,photos weight differances perfomance info would greatly be appreciated. P.S...I also already know the performance gains with the full system and know how much is dropped with that system. I'm just curious of the results somone has attained with this set up as I may go that rout.
JTinFL is offline   Reply With Quote
Old Feb 3rd, 2009, 7:23 am   #2 (permalink)
There has been a post befor on this topic. I did on a R1 before just for that reason because I liked the look of the stock exhaust and it worked out great and was really easy to do. Performance was great for about $60 and one hour of work.
I have a cheap stock experimental exhaust if your interested. If you don't have one at your shop.
jdubcee is offline   Reply With Quote
Old Feb 4th, 2009, 9:24 pm   #3 (permalink)
JTinFL's Avatar
Has it been modified?? Do you(by chance)have the tread about the modified exhaust???
Old Feb 5th, 2009, 7:09 am   #4 (permalink)
The stock exhaust for the HM that I have has not been modified. Try doing a search for the modifed exhaust.
Old Feb 5th, 2009, 9:58 am   #5 (permalink)
Treadmarks's Avatar
Try these:
It was SM171's fault!! @#*&!
Standard Exhaust Shinanigans
Cored Exhaust??
TREADMARKS
Ford F150 4x2 Lifted
Treadmarks is offline   Reply With Quote
Old Feb 5th, 2009, 11:37 am   #6 (permalink)
fred51's Avatar
Jt give me a call ,I can tell you anything you need to know about coreing the stock pipes.
Donald 337-344-2725
fred51 is offline   Reply With Quote
Does anyone leave the stock exhaust on? hawc Surveys and Polls 46 May 14th, 2012 1:31 am
Exhaust Modifications....stock! DonnyO Sport Touring 28 Oct 22nd, 2010 7:12 am
Stock 2 into 1 Exhaust 1997 900ss? rudedog Supersport 16 Jul 27th, 2008 5:33 pm
st4 stock exhaust modification jerryr Sport Touring 2 Feb 4th, 2006 2:37 am
