Clutch Lever Plunger Question - Ducati.ms - The Ultimate Ducati Forum
Old Feb 1st, 2009, 3:24 pm   #1 (permalink)
Caidly's Avatar
Question Clutch Lever Plunger Question
When changing the clutch lever, how do I remove the black plunger from the old lever to get it onto the new lever?
TIA.
if you need to know... ask...
Old Feb 1st, 2009, 3:26 pm   #2 (permalink)
Brainfry's Avatar
I beat the crap out of mine til the cut out deformed and stretched enough to pull it out. Can't reuse the lever, but no biggee. I seriously didn't see any other way. Maybe someone else has a solution if you want to keep the OEM lever.
B
Never enough garage space.
'05 BMW K1200LT
'07 BMW R1200GS Adventure
'08 Ducati Hypermotard S
'10 BMW S1000RR
Brainfry is offline   Reply With Quote
Old Feb 1st, 2009, 4:11 pm   #3 (permalink)
Caidly's Avatar
Got it. I removed the dowel that holds the adjuster to the lever, slid it out and re-inserted the dowel, making sure the little spring in the back didn't come out.
Hydraulic Clutch Question clt750 Superbikes 2 Jul 29th, 2008 12:15 pm
Clutch Lever Disassembly Question Motophoria Sport Touring 2 Jun 26th, 2008 6:37 pm
Slipper clutch installation question dutchduc900 Superbikes 7 May 19th, 2007 12:49 am
Ducati Dry Clutch question . . . 2ducks Ducati Motorcycle Chat 36 Jan 18th, 2007 4:40 pm
Clutch Hub Question '93 900ss TheToeCutter Supersport 5 Dec 16th, 2006 4:06 am
