Jan 23rd, 2009, 10:18 pm
Anyone dislike the lightweight flywheel?
Just curious. With the "bad" weather this weekend, I thought I would take the opportunity to pull my flywheel and cut some weight.I'm planning removing as much material as structurally possible which should leave it somewhere between the DP product and the Nichols which of course is aluminum. I guess my question is has anyone experienced any ill effects from the light flywheel? i.e. loss of traction especially on wet roads?
Jan 23rd, 2009, 11:24 pm
quite possibly the single best mod I've made to the bike. it transforms the willingness of the engine to rev. down shirts are a no-brainer. bange em down and it spins right up. the most underrated mod, IMO
THe Keihin FCR41s are a close second. They make a ton more power, but if I still had the OEM flywheel, it would still like it was running in molasses.
I got the Yoyodyne, which I understand is just slightly more weight than the Nichols, and I'v experienced absolutely no downside. it's had a positive impact on performance, revability, downshifts, handling. really, a great mod.
_______________________
Present:
'94 900SS|SP #143
'98 Yamaha R1
Jan 24th, 2009, 12:44 am
i also would like to try this d.i.y lightened flywheel mod, will you post before and after pics please
Jan 24th, 2009, 1:58 am
Excellent mod - one of the best
Current Stable:
2008 HYM 1100
2008 RXV550
2007 CRF450
2001 CR250
Jan 24th, 2009, 2:03 am
for the $$$$ its the best thing I have done. More power to the ground faster. It also reduced wheel hop on hard deceleration, almost like a slipper but not quiet
Jan 24th, 2009, 12:16 pm
whats the part # on the Yoyodyne flywheel? TIA Alex
Jan 24th, 2009, 12:49 pm
Moderator
Definitely a good mod for less than changing wheels...
Got Nichols lightweight flyweel, and that is a great improvement.
Jan 24th, 2009, 2:33 pm
Performance Center
Here is a comparison of the 3 phaze flywheels:
Top left are (stock) on 1999 thru 2006's (748/999,ST4ect..)5 lbs.
Top right are (stock)on 1098's, Hyper's ect.. 4 lbs.10 ozs.
Bottom right are (stock) on 848's and 1098R's 2 lbs. 3 ozs.
Bottom left is after we machine/bal. them 1 lb. 12ozs.
Jan 24th, 2009, 4:31 pm
Why did Ducati choose a heavy flywheel for the HYM?
From that picture you posted, does the newer 848/1098 flywheel bolt up to the HYM?
Did any of those running light weight flywheels experience a loss of momentum in the lower RPM's when cruising? I'd assume the heavier flywheel helps keep the engine stalling when cruising below 3krpms.
Jan 24th, 2009, 6:05 pm
I would think that if infact the flywheels are different weights that it was an attempt at keeping the frnt wheel down.
