Originally Posted by kingsnake1650
you could hook the actuator box back up an just undo the cables that go to the flapper. the light doesnt come on untill the actuator is unpluged
Except that with my '08 ECU, there is an exhaust valve test that occurs
every so often at key on which checks the full range of the exhaust valve
assembly. With no hardware in place to limit the rotation of the stepper
motor, an over-travel error will result. There are a number of ways to
limit the travel of the stepper motor pulley-- see the archives here. I
prefer to remove the cables and tap two 25x6mm bolts into the side of the
pulley to serve as stops, but some have incorporated stops onto the
cable ends themselves. You could choose to ignore the Check Engine
light, but then you would not notice other failures...
