Can somebody look this up please? - Ducati.ms - The Ultimate Ducati Forum
Old Jan 19th, 2009, 6:55 pm   #1 (permalink)
unfast1's Avatar
Don't know where the hell my manual is.
Went to load the bike up to take back to the shop for the 6th time because of stalling and I get a new code. They are going to degree the cams to try and fix the stalling what ever that means. If you know please explain..
Any way the code is 23.2 EXVL. Maybe exhaust valve???
Thanks.
2008 Black Hyper S
2005 CBR 1000RR
2001 CBR 929RR
1997 GSXR 600
unfast1 is offline   Reply With Quote
Old Jan 19th, 2009, 7:32 pm   #2 (permalink)
You're gonna love my nuts...
Borracho's Avatar
According to this:
http://www.ducati1098.net/forums/showthread.php?t=10011
Exhaust valve.
Old Jan 19th, 2009, 9:37 pm   #3 (permalink)
unfast1's Avatar
Those are different for a Hyper but, it's probably the valve.
2008 Black Hyper S
2005 CBR 1000RR
2001 CBR 929RR
1997 GSXR 600
Old Jan 19th, 2009, 9:40 pm   #4 (permalink)
Borracho's Avatar
I heard that some of the error codes span across the 2007+ models but seeing that I only own a Hyper and not a superbike; what do I know
Good luck with it nonetheless.
Old Jan 19th, 2009, 9:58 pm   #5 (permalink)
hyperdookie's Avatar
Images: 9
EXVL 23.2=exhaust butterfly valve motor error
Old Jan 21st, 2009, 6:43 pm   #6 (permalink)
Caidly's Avatar
Take off your seat and make sure the cables were properly routed. I remember (but can't find) some thread that showed the cables rubbing something they were not supposed to.
if you need to know... ask...
Old Jan 24th, 2009, 4:54 pm   #7 (permalink)
Don't worry about the code. it is for the exhaust butterfly valve.... But that is not your problem. The dealer will just reset the light & tell you it happens sometimes??? The problem is the screwed up stock ECU ducati made these bikes with. Mine does the same thing stalls, check engine codes along with many other guys with the stock ECU. Good luck on having the dealer install a performance ECU (which will solve all your problems) under warranty. Been there.
GOOD LUCK with your bike!
RedDuc999 is offline   Reply With Quote
