Lambda - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jan 17th, 2009, 8:11 am   #1 (permalink)
Persuaders's Avatar
Lambda
Hello,
I'm called Guillaume, have a HM (07/07) [edit].
I have a question to ask you (I sought but not found … ): does there exist a “misleading” lambda's sensor.
I removed the cata and obviously I have the yellow indicator which ignites. How to make for extinguish this indicator without changing ECU??
Thanks a lot.
For information, "passage to the bench"
Moto : 16.000 kms
Configuration 14/12/08: Y (removal of the cata and lambda's sensor) + open Case FAA DP + kN + ECU DP (for the 2 in 2) -->
Configuration 21/12/08: Y (removal of the cata and lamda's sensor) + open Case FAA DP + kN + origin ECU -->
Nb: sorry for my "bad" English…
Persuaders is offline   Reply With Quote
Old Jan 17th, 2009, 1:22 pm   #2 (permalink)
johnchypermotard's Avatar
ciao Guillaume -
no worries about your english ... i suggest that you send a pm to cassos (christian), as he is french, but we can "just" understand his english ... so he can translate
Old Jan 17th, 2009, 2:33 pm   #3 (permalink)
Persuaders's Avatar
Thanks John and ... excellent cause I "know" Christian !!
Christian, I need your help. If you can translate my first message ... Thanks a lot.
Originally Posted by johnchypermotard View Post
ciao Guillaume -
Old Jan 17th, 2009, 8:42 pm   #4 (permalink)
you know christian?
<thick french accent>i fart in your general direction </thick french accent>
Old Jan 19th, 2009, 1:10 pm   #5 (permalink)
Moderator
cassos's Avatar
Salut Guillaume,
I will contact you in French, in meanwhile the situation is as follows.
There are 4 types of ECU for the Hypermotard:
#1 Ducati Stock ECU
#2 DP ??? ECU = with Termi Slip-on = 8% more fuel, no O2 sensor = Ducati Part # 96519308B
#3 DP Evo ECU = with Termi Full system = 8% more fuel, no O2 sensor, no
exhaust valve = Ducati Part # 96518708B
#4 DP Race ECU =with Race Cams = 18% more fuel, no O2 sensor, no exhaust
valve = Ducati Part # 96519208B
I forgot what welcome message is on the dash with ECU #2 when you turn on the ignition, can someone check... thanks.
Anyway, you seem to have the #2, so you do NOT need any O2 sensor / lambada emulator,
(although they do exist, I don't have links).
You have to check the error code that generates the yellow light on your dash, but I bet it is most likely related to the exhaust valve.
The real solution is to change your ECU, most of us with LV slip-on and LV cat eliminator bought the race cam kit to get the ECU #4 (Race ECU).
Christian.
cassos is offline   Reply With Quote
Old Jan 20th, 2009, 7:13 pm   #6 (permalink)
GHEZZI's Avatar
Hey Cassos,
I've got a Hyper 'S' with Zard Top Gun slip-ons & open air box lid, when I fitted a 96519308B it first shows 'EU', then all numbers and lights then scrolls "H-Y-M R-A-C-I-N-G" across the screen. Stock is H-Y-M 1-1-0-0.
My bike ran so rich I lost 20hp, 20kph, and 4km/l, so I removed it, tapped up the air box and added an O2 manipulator instead.
My DP ECU also has another sticker 'SBA9SHA4' ???
You state the 308B I have has no O2 sensor, my bike still has the cat & O2 fitted so I assume the DP ECU does not recognize them? Strangely, the slip-on and full system DP ECU's both increase fuel 8%.
Lambda sensor removed 2-1-2 termis? sinex HyperMotard 1 Nov 16th, 2008 11:57 pm
1098 Questions hondav2 Superbikes 8 Oct 8th, 2008 4:45 am
Lambda Sensor richardmontgomery Sport Classic 2 Jun 3rd, 2008 7:50 am
New Magneti Marelli ecu varden Ducati Motorcycle Chat 46 Nov 4th, 2007 5:31 pm
termi install, lambda sensor? h2omonkey Sport Classic 2 Oct 20th, 2007 2:18 pm
