Leo Vince - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jan 16th, 2009, 11:08 am   #1 (permalink)
Leo Vince
Hi,
I thought i would introduce myself, my name is Col and i picked up a 07 Hyper last Wednseday and i am in love, this by far is the best bike i have ever owned.
Anyway my question is are the Leo vince slips-ons any good and easy to fit, i noticed on the standard system there is a bracket with a couple of lines attached these seem to removed with the leo's is this a problem? and can you run them on the standard ECU with no issues?
hyperCol is offline   Reply With Quote
Old Jan 16th, 2009, 11:38 am   #2 (permalink)
Location: Northern, , Ireland (Ducati Hypermotard 2012 evo corse 1100)
Congratulatoins
Just to congratulate you on you new hyper. I too have just bought one and the dealer is to deliver it tomorrow morning. Can't wait to get a run on it
Darsey is offline   Reply With Quote
Old Jan 16th, 2009, 11:55 am   #3 (permalink)
Cheers, you will love it i enjoy looking at it nearly has much as riding it. Now starting to add some bling i can't quiet stretch to the full termi system though so looking at cheaper alternatives.
Old Jan 16th, 2009, 12:16 pm   #4 (permalink)
johnchypermotard's Avatar
ciao col -
congrats.
the leovince slip on system is a great upgrade to the stock hypertard. high quality bits, and an easy installation.
you can run the leo system with the stock ecu, but you will need to keep the lambda sensor installed if you do so, otherwise the dash will throw error codes. if you get just the slip ons, this is not an issue, as you will keep the cat intact. if you get the cat eliminator (highly recommended) and want to run the stock ecu, just transfer the lamda to the leovince cat eliminator.
both of the above installations will allow you to use the stock ecu, but you should consider upgrading to one of the dp race ecus (there are three available now; slip ons, full system and race cams). do a search in this forum on race ecus, and you will find a thread that details the differences in air/fuel ratios these three ecus provide. when i was running the leos on my hypertard, i had the full system ecu ... worked great.
the other mod you should consider doing on your new hypertard is cutting a hole in the airbox lid and running a k&n or bmc air filter. this mod alone adds about 4 hp to the stock hypertard. cut a 2 1/5" hole in the top of the lid, right over the airfilter ... link: DP Airbox Lid
once you add the leo system, do the airbox mod and install one of the race ecus, you will notice a huge difference in the power delivery on your hypertard ... the hp and torque will come on much smoother.
we dyno'ed my hypertard base/stock, and right after the airbox and leovince mods ... gained hp and torque across the entire range. link: HyperMotards.net dynos at Nichols
a presto,
johnc
Old Jan 16th, 2009, 12:25 pm   #5 (permalink)
Thanks Johnc,
Just the info i was after, i am going to order the slips-ons tomorrow any potential problems or just straight forward to fit?. The next purchase will be the dp cams and i will do the airbox lid mod and bmc filter at the same time.
Old Jan 16th, 2009, 1:01 pm   #6 (permalink)
Originally Posted by hyperCol View Post
Thanks Johnc,
no issues with fit ... leovince even includes a spring removal/installation tool with their kit (a nice touch, imho).
figure about 2 hours wrench time required to remove the stock bits and install the leovince slip ons.
installation tip: keep all the nuts/bolts loose until you get all the parts installed, then align everything and tighten to proper torques.
a presto,
johnc
Old Jan 16th, 2009, 1:58 pm   #7 (permalink)
I agree.I think the LVs look the best too.The only potential prob you might have with the stock ECU is an error code because you'll have to remove the exhaust flapper valve ( which you dont have to with the Termi 2-2 slip ons. Some have the code some dont - go figure.I have done similar things to you: LV cans, cat elim,BMC filter/free DP airbox lid and also the DP ECU for the 2-1 system ( which also eliminates the exh. flapper valve).I adjusted fuel trim using the VDST.
If you search for posts on for Leo Vince, ECU etc you'll see its all be done.
Easy installation , but it took me more like 3 hours- but then I'm 'special'.
Before the BMC filter ( which was not the best fit I might add), I have 90 RWHp.
Just my 2c
Jonathan
Old Jan 17th, 2009, 9:36 am   #8 (permalink)
Lifetime Premium
Images: 59
The build quality is exceptionally good on the LV, at least compared to the Termi 2-1 I have.
Bill
2008 KTM 990 Adventure
2007 KTM 640 Adventure
2004 KTM 300 EXC
2003 KTM 525 EXC
1991 Ducati 851
1978 Moto Guzzi Lemans I
1974 Yamaha RD350
1931 Moto Guzzi 2VT
Old Jan 17th, 2009, 11:07 am   #9 (permalink)
Sorry to sound stupid but is the flapper valve easy to remove and if it brings up an error code does it have any negative effect on the bike other than just bringing a code up.
Old Jan 17th, 2009, 11:22 am   #10 (permalink)
couchflyer's Avatar
Images: 54
... if it brings up an error code does it have any negative effect on the bike other than just bringing a code up.
Great question. Also does the VDST allow you to cancel that error code on a stock ECU?
2008 Hypermotard 1100s
2008 1098
Sola Gratis
couchflyer is offline   Reply With Quote
Leo Vince Cat? sloduck HyperMotard 4 May 14th, 2008 12:18 pm
For Leo Vince owners ONLY!!! 08hyper HyperMotard 17 May 7th, 2008 2:26 pm
anyone ceramic coated Leo Vince? osayek Superbikes 15 Mar 19th, 2008 1:36 pm
