Ducati bash plate doesn't fit with the Termi 2-1 system? - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Jan 12th, 2009, 8:39 pm   #1 (permalink)
EarthBM's Avatar
...'cause the pipe is too close to the sump? Or is it my subpar fitting skills?
EarthBM is offline   Reply With Quote
Old Jan 12th, 2009, 8:49 pm   #2 (permalink)
08hyper's Avatar
Question
Thats wierd, usually DP parts will work together. Aloha Alex
Old Jan 13th, 2009, 12:43 am   #3 (permalink)
That is a bit odd... mine fits just fine. Unfortunately the bike is taken apart so I can't get a pic for you at the moment.
2009 Aprilia RSV4 Factory (finally arrived)
2008 Red Hyper 1100S
2008 KTM 690 Duke
2007 Honda CBR600RR
colacin is offline   Reply With Quote
Old Jan 13th, 2009, 1:15 am   #4 (permalink)
Fly Low...
Karna's Avatar
works fine picture enclosed...
Hope this helps... cant see it from the exhaust side but I enclosed bottom view...
All the best..
Ducati bash plate doesn't fit with the Termi 2-1 system?-skid-plate.jpeg   Ducati bash plate doesn't fit with the Termi 2-1 system?-img_0518.jpg
Karna is offline   Reply With Quote
Old Jan 13th, 2009, 11:22 pm   #5 (permalink)
EarthBM's Avatar
Thanks, will 2nd try then...
Old Jan 14th, 2009, 7:12 am   #6 (permalink)
AbzPhil's Avatar
It will fit, just ignore some of the instructions.
1: Fit the brackets first, then attach the plate.
2: The rear bracket will fit, I used a large persuader (hammer) on mine, as there is almost fa clearance between sump and exhaust.
3: The metal spacers behind the footrests need to be removed, IIRC the gear side goes back in, the brake side doesn't. Replace after you get the bracket in place.
4: There is a plastic/rubber spacer type thing behind the foot rest on the brake side make sure this doesn't get squashed up, you will be able to see through the bolt hole.
Have fun and dont swear too much
AbzPhil is offline   Reply With Quote
Old Apr 7th, 2009, 9:47 pm   #7 (permalink)
MultiModerator
vduc's Avatar
Images: 70
My DP sump guard / bash plate didn't come with any instructions, does someone have them that they could post or email?
I think I have it on right but I want to confirm. I remove the washers on the both sides where the bracket attaches. On gear side it was only the thinner one of the two. I put the thicker alum. one back in.
It clears the Termi 2 into 1 system no problem
It was a PITA to get the plate mounting nuts on to the brackets afterward. Is there a trick to easily getting it out of the way for an oil change?
Thanks
Vito
93 750SS - 10 Hypermotard EVO SP - 04 aprilia RSV1000 Factory
vduc is offline   Reply With Quote
Old Apr 8th, 2009, 12:47 am   #8 (permalink)
08hyper's Avatar
Thanks
Your good to go, the skidplate brackets just replace the 2 thin washers.
You can JB weld the nuts to the brackets or put on clamp nuts, (U bracket with built in nuts) that way you just remove the screws to take off the skidplate. Aloha Alex
Old Apr 8th, 2009, 7:30 am   #9 (permalink)
MultiModerator
vduc's Avatar
Images: 70
JB Weld to the rescue Thanks for the confirmation and suggestions.
Vito
Old May 23rd, 2012, 8:02 am   #10 (permalink)
Hi - could i just tag on to this......ive just got my HM and the bash plate didnt come attached. mines got a zard exhaust on there (which isnt the issue i dont think) but my problem is, is that the washers that drop out (the ones that are about 25mm across are half as thick as the bash plate mount that has to go back in (the front holes are fine) if i try to push the rear (were talking the right hand side here as you sit on the bike) then it just squashes the rubber up - and if i have to take the whole lot off then is there much point putting it on??
comfysofa is offline   Reply With Quote
Quat-D Full System Installation Review and Pics! bmartinek HyperMotard 24 Aug 14th, 2008 11:24 pm
Termi 2in2-Full System (not just slip-ons) george_v HyperMotard 3 May 21st, 2008 8:20 am
so what comes with a Termi 1/2 system? blurry Superbikes 11 Apr 7th, 2006 5:26 pm
Termi asymmetrical to full system conversion black749s Superbikes 8 Apr 5th, 2006 5:56 pm
Does the termi half system included with a 999s fit a base 999 (03/04) UndergroundLare Superbikes 10 Mar 30th, 2006 7:36 pm
