Termi 2 into 1 question - Ducati.ms - The Ultimate Ducati Forum
Old Jan 4th, 2009, 3:00 am   #1 (permalink)
Banned
I have a stock exhaust I want to put back on the Hyper. The base I work on wont let me on with the Termi. I was curious if the race ECU could be used with the stock exhaust system with any advantage.
Any thoughts or interest?
Brock
850.867.9710
Los Angeles
28482 is offline   Reply With Quote
Old Jan 4th, 2009, 11:17 am   #2 (permalink)
Lifetime Premium
Images: 59
I suppose the answer depends in part on whether you intend to reconnect the exhaust valve. If you reconnect it, then you must reinstall the stock ecu since the 2-1 ecu has no exhaust valve control capabilities.
I seem to recall that some have disconnected the exhaust valve even when running the stock ecu, pipes and cans; however, I don't know why anyone would do this. There may be a legitimate reason, but I don't know what it is. In any case, I suspect the 2-1 ecu would be way rich for the stock cans regardless.
If you change the ECU back to stock, you will need to reset the TPS.
Bill
2008 KTM 990 Adventure
2007 KTM 640 Adventure
2004 KTM 300 EXC
2003 KTM 525 EXC
1991 Ducati 851
1978 Moto Guzzi Lemans I
1974 Yamaha RD350
1931 Moto Guzzi 2VT
Old Jan 4th, 2009, 1:32 pm   #3 (permalink)
GMP
I ran the stock exhaust with an LV cat eliminator and no exhaust valve for months using the 2 -1 DP ECU with good results. You just need to set the trim a bit leaner. Forget the stock ECU, its way too lean.
Doesn't the Termi have an insert to kill a few db? If you need a quieter pipe, trade/sell the Termi for an LV system (has inserts), I run mine with the inserts and its quiet enough riding casual but still barks when you get on it. Dyno numbers are very close to the Termi and it saves a few lbs. over the stock system.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
999 Termi Half System Question DJM Superbikes 19 Aug 1st, 2008 10:23 pm
termi exhaust question on an 05 999 jonsgon Superbikes 13 Feb 19th, 2008 1:30 pm
57mm Termi Burn Fairing question NickyD999 Superbikes 13 Nov 7th, 2007 9:32 pm
Another Interminable Termi Question weazoe Sport Classic 5 Aug 15th, 2007 7:21 am
Termi 2:1 Question (again) AM1001 Sport Classic 30 May 28th, 2006 12:31 am
