POS Stock chain - Ducati.ms - The Ultimate Ducati Forum
Old Dec 31st, 2008, 9:12 pm   #1 (permalink)
POS Stock chain
Anyone else notice all the rubber O rings coming out the stock chain?
after a trackday I picked 4 up from the top of the swingarm and whenever i clean the chain I see them sticking out. I clean the chain same way I've done very other one using the same stuff so I know its not me.
what is the stock anyway? 525 and how many links?
Old Dec 31st, 2008, 9:41 pm   #2 (permalink)
parkcrf's Avatar
Switch out and do the 520 conversion go DID or RK
Current Stable:
2008 HYM 1100
2008 RXV550
2007 CRF450
2001 CR250
Old Dec 31st, 2008, 10:05 pm   #3 (permalink)
GHEZZI's Avatar
18,000klm stock chain still ok, ?????
Old Dec 31st, 2008, 10:07 pm   #4 (permalink)
alounacara's Avatar
I want the red chain
2008 Hypermotard
1994 ZX9R Kawasaki gone and good riddance
Houston Texas
alounacara is offline   Reply With Quote
Old Jan 1st, 2009, 4:28 pm   #5 (permalink)
did a 520 conversion on my last bike, didn't notice much difference. not worth the extra $$$ for the different cogs. 525 is fine, I'll get a DID X-ring thingy sometime
Old Jan 1st, 2009, 6:52 pm   #6 (permalink)
Lifetime Premium
SURVEYOR's Avatar
what do you use for cleaning?
What do you use for cleaning? Some products will melt the o-rings
AMSOIL DEALER
06 MTS 750 SPS
08 HYPER BLACK
BOTH SERVICE & MODIFIED AT EASTSIDE MOTOSPORTS, BELLEVUE, WA, USA
SURVEYOR is offline   Reply With Quote
Old Jan 2nd, 2009, 2:00 am   #7 (permalink)
I use O-ring safe wax and for a big clean so called o-ring safe chain clean spray. I just wipe off old with a rag till its clean and spray on new wax and mop up excess. that's it, nothing invasive like brushes etc.
Old Jan 2nd, 2009, 7:54 am   #8 (permalink)
Caidly's Avatar
You're supposed to clean your chain?
if you need to know... ask...
Old Jan 2nd, 2009, 8:41 am   #9 (permalink)
GMP
I've never seen that, even in years of off road riding and heavy chain maintanence. I also use the chain wax (Maxima). For the Duc I just clean with WD40 and a rag occasionally (if the chain looks gritty) and re-lube, but for the dirt bikes Simple Green and a nylon brush, rinse with a hose, ride to dry out and then lube. What brand cleaner to you use?
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Jan 2nd, 2009, 4:05 pm   #10 (permalink)
scooter's Avatar
This is precisely my chain maintenance program, both on the Hyper and my older GT. WD-40 and Maxima wax are a great combo and the Maxima stays on the chain better than most products. No problems whatsoever. Whenever I clean the chain, I also check all the obvious fasteners and tighten up anything that needs it.
On my bicycle, I've used White Lightning products for years and really like them. Anyone try them on motorcycle chains? Just curious...
Andy
08 Hypermotard S (red)
07 GT1000 (gray), traded for Hypermotard
06 Genuine Buddy 125
04 Aprilia 50cc 2 stroke, 65 cc cylinder head, touring exhaust, RIP
Custom road bike, Ciocc steel frame, campy road set
scooter is offline   Reply With Quote
15/44 with stock chain GMP HyperMotard 0 Sep 18th, 2008 8:33 pm
999s Gearing Change Soarer Superbikes 8 Jul 18th, 2007 10:45 am
proper measurment of chain slack Geof3 Superbikes 8 Dec 26th, 2006 7:25 pm
Chain Making Bad Sounds Stang65 Supersport 23 Oct 6th, 2006 7:13 am
