Dec 31st, 2008, 9:31 am
Alternative Battery
Thought some of you might be interested in this. Lighter weight Lithium battery. You'll find some interesting test comments and more detailed specs near the bottom of the thread.
http://ktmtalk.com/index.php?showtop...wer%20now&st=0
2.5Ah 0.8lbs....$ 70.00
5.0Ah 1.7lbs....$130.00
If your wondering, the stock HM battery is 12V 520W 10Ah. So, he's not there yet for the HM but worth watching. For some of the dirtbikers, cool option here.
'08 HM 1100 S
