Spring adjuster Öhlins rear shocks - Ducati.ms - The Ultimate Ducati Forum
Old Dec 26th, 2008, 1:21 pm   #1 (permalink)
Description from Kämna in Germany.
From aluminum manufactured spring shim for Öhlins shock struts. Functioned purely mechanically. Screw on simply. The spring temper is adjustable with this ring by hand. For the assistance the lever can be used. The ring becomes secured with set-screws. Simply however effectively! Scope of supply: Lever and ring.
Seems to be a really good solution for the problem with the alu/plastic oem nut on the Öhlins shock.
Why just ride when you can ride with passion !? Ride Ducati !!
LN2VIOLN2 is offline   Reply With Quote
Old Dec 26th, 2008, 4:45 pm   #2 (permalink)
hyperdookie's Avatar
Images: 9
Not sure I understand.Does the set screw "set" into the shock body threads?
Old Dec 26th, 2008, 5:35 pm   #3 (permalink)
Banned
Sure looks like, I think I'd rather have a second one as a locking ring instead of screwing up my threads.
Old Dec 26th, 2008, 8:18 pm   #4 (permalink)
08hyper's Avatar
Thumbs down
Yep, that type of lock system will "dent" a couple of shock threads, only to be cleaned up again when you turn the adjuster, but the "dent" on the threads will still be there....so if you adjust your preload alot, you'll have a "denty" shock! but worse yet, if you forgot to loosen the set screw, and went and adjusted the shock spring, you could wipe out a lot of threads! a double aluminum nut set-up or a huge nylock, would seem like the way to go. Aloha Alex
Old Dec 26th, 2008, 8:41 pm   #5 (permalink)
daversj's Avatar
I replaced the platic unit with an aluminum one from Ohlins USA in North Carolina. The part was about 30 bucks. They were aware of the problems with the plastic adjuster.
2008 Hypermotard Temrmi Slipon w/ Zard collectors & Mid pipe, 2 into 1 Termi ECU
daversj is offline   Reply With Quote
Old Dec 27th, 2008, 11:20 pm   #6 (permalink)
PJFZ1's Avatar
Contact info for them? My Hyper is going Matris, but I'd like to replace the plastic ring on the stocker so it's right.
If loud pipes save lives, imagine what learning to ride that thing could do!
PJFZ1 is offline   Reply With Quote
Old Dec 27th, 2008, 11:54 pm   #7 (permalink)
08hyper's Avatar
Thumbs up here you go.....
Originally Posted by 08hyper View Post
RE: (Lets talk about Frikkin' OHLINS!!!) thread by AZ_Scott
For "S" owners with Ohlins shock that have the plastic jam nut below
the metal one, you now have 2 options. Option #1 first leave it alone, and if
the shock gives you a problem, IT IS a Ducati problem, because Ducati had
Ohlins make the shock to THEIR specifications, and so it will be covered
by your warrantee, providing your in the bike's warrantee period. Option #2
Ohlins USA, is AWARE of the problem, and they want to help! if you send
them your shock, (you pay for shipping) and $20.76, cost for the aluminum
ring, part #531-01 they will do all the repair labor for free, and send you
back your shock. As a bonus, if you tell Ohlins what model Ducati you have,
your weight, your skill level, they will for $89.99, install the correct spring
rate spring for you, just like a CUSTOM made shock.
West Coast riders, send your shock to Walt Schonauer, (Ohlins sales Rep)
12301 Mills Ave. #25 Chino, CA 91710 Tel. (951) 712-9463
East Coast riders, send the shock to Ohlins USA, Inc. 703-C
Old Spartanburg Rd. Hendersonsville, NC 28792 Tel. (828) 692-4525
So now we ALL know, Alex
"from my previous post"
05 999 rear spring info needed jonsgon Superbikes 7 Apr 13th, 2008 11:44 am
Rear Shocks on GT Kenneth Sport Classic 4 Oct 15th, 2006 5:45 pm
ST3 rear spring preload ducaati Sport Touring 7 Jul 21st, 2006 9:32 am
Rocks around rear shock/height adjuster mount TORC Superbikes 1 Jan 29th, 2006 7:29 pm
