need help
has anyone experienced this case? after you brake for fews second, the engine stop . this happens with all gears (1 2 and N). and then when u start agian, the engine will on for 2 seconds and then off again, unless you speed up RPM of the engine. however, the driving is just fine.
PS. i have changed the CAM, FULL Exhaust system. and i have used ECU of the racing CAM.
now my bike is with ducati technical in thailand. however, they are still looking for the cause of this trouble since they have found no error from their ECU. I wish i could ride on new year. pls, i need help.
