Dec 23rd, 2008, 4:00 am
ecu's for cams
Hi Chaps
do I need a new ecu for cams if I already have the ecu for the single sided race pipe and full system?
Any advice would be welcome before I shell out my rapidly becoming valueless pounds against the mighty euro.
Dec 23rd, 2008, 6:37 am
Originally Posted by Karlr
Hi Chaps
From another thread here.
1) Stock
2) Slip-on = 8% more fuel, no O2 sensor = 96519308B 2-1-2
3) Full system = 8% more fuel, no O2 sensor, no exhaust valve 96518708B
4) Full sys w Cams = 18% more fuel, no O2 sensor or valve = 96519208B
TREADMARKS
Ford F150 4x2 Lifted
Dec 23rd, 2008, 10:57 am
Duc ... Duc ... GOOSE!
I was under the impression that the Slip-on ECU also disabled the valve. I don't remember seeing the valve as a "selectable" menu option on my VDSTS when I had the slip-on ECU installed.
-Marco
Dec 23rd, 2008, 3:56 pm
My slip on ecu disabled the valve and I didn't see it as a selectable feature either. Seems like I've read here that some do an some don't.
TREADMARKS
Dec 25th, 2008, 4:40 am
1) Stock
ahh i have full system and ecu..do i need a new ecu for cams with full system
or does the above tell me this?
Dec 25th, 2008, 1:42 pm
The short answer is YES.
Of course, you could probably get the ECU that you currently have to work if you get a PCIII or RapidBike module and dyno tune it.
Of course, if you buy the cams they should come with an ECU so it's a moot point.
-Marco
