my dyno run :LV cat/pipes/..708B ECU/VDST - Ducati.ms - The Ultimate Ducati Forum
Old Dec 19th, 2008, 5:56 pm   #1 (permalink)
here we go
mmm didnt seem to work so well
Old Dec 19th, 2008, 6:31 pm   #2 (permalink)
Those are good numbers. Strange graph though, the axes make the curve look really steep.
breakdown is offline   Reply With Quote
Old Dec 19th, 2008, 7:47 pm   #3 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Your numbers are good for those mods. A print-out of your air/fuel ratio would also help you get it dialed in a little better.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old Dec 19th, 2008, 8:50 pm   #4 (permalink)
that's coming!
the AFR was pretty much spot on with the VDST-S set at '0' trim ( started at 10 and went backwards.)
Pretty much 13.5:1 until higher ( 6.5K and above ) where it was a bit rich.Apparently twins like to be around 13:1.
Very happy- no need for PC3.
jonathan
Better Throttle Response, Less Surging and Popping? - Clike Here jborders5 Sport Classic 295 Jul 16th, 2009 10:22 pm
Zard Top Guns Dyno Run AXE HyperMotard 27 Dec 21st, 2008 12:26 pm
1098R Dyno run 187.7HP Shift-Tech Superbikes 15 Oct 5th, 2008 3:33 pm
Sport Classic 1000S Dyno Run - Power commander & Termi's glenndesmo Sport Classic 9 May 14th, 2008 12:41 am
Desmosedici (D16RR) Dyno Run Chris848 Ducati Motorcycle Chat 11 Apr 19th, 2008 6:08 pm
