GPS electrical wiring help - Ducati.ms - The Ultimate Ducati Forum
Old Dec 12th, 2008, 9:58 am   #1 (permalink)
couchflyer's Avatar
Images: 54
I have mounted my GPS, ram mount, now I am wondering the best way to wire in the outlet socket. I will be using the powerlet plug. So how did you guys wire your GPS? Photos will help.
Thank you
2008 Hypermotard 1100s
2008 1098
Sola Gratis
couchflyer is offline   Reply With Quote
Old Dec 12th, 2008, 12:29 pm   #2 (permalink)
I hard wired my Zumo 550 right into the battery. I take it you need the socket?
STICKER is offline   Reply With Quote
Old Dec 12th, 2008, 2:26 pm   #3 (permalink)
Brainfry's Avatar
Ditto. Straight off battery. In line fuse.
Never enough garage space.
'05 BMW K1200LT
'07 BMW R1200GS Adventure
'08 Ducati Hypermotard S
'10 BMW S1000RR
Brainfry is offline   Reply With Quote
Old Dec 12th, 2008, 3:04 pm   #4 (permalink)
sm171's Avatar
I hard wired my Garmin Map60 into the battery. Used a waterproof fuse holder and connectors. Did the same on my enduro bike and it's never failed.
Mike
08 Ducati HM1100
08 KTM 450 EXC-R
sm171 is offline   Reply With Quote
Old Dec 12th, 2008, 3:10 pm   #5 (permalink)
bromike666's Avatar
Doesn't that mean that if you forget to turn off your GPS that the battery goes dead?
I had mine wired into the fuse box when PI was putting in my heated hand grips. Turns on and off with the key, no chance of battery drain.
"I love the sound of a dry clutch in the morning"
10 F1098S Streetfighter
08 Hypermotard 1100S
08 Multistrada 1100S
07 SM610
bromike666 is offline   Reply With Quote
Old Dec 12th, 2008, 6:40 pm   #6 (permalink)
Lifetime Premium
Images: 59
Heated grips in So. Cal? You sissy. Nevermind the fact I also have heated grips and they are almost always on.
Bill
2008 KTM 990 Adventure
2007 KTM 640 Adventure
2004 KTM 300 EXC
2003 KTM 525 EXC
1991 Ducati 851
1978 Moto Guzzi Lemans I
1974 Yamaha RD350
1931 Moto Guzzi 2VT
Old Dec 12th, 2008, 8:05 pm   #7 (permalink)
couchflyer's Avatar
Images: 54
I need the plug because I use the GPS on two bikes. Here is the plug in the ST-3. I have a bracket for the socket, I am looking for ideas for the socket location.
2008 1098
Sola Gratis
Old Dec 20th, 2008, 3:01 pm   #8 (permalink)
couchflyer's Avatar
Images: 54
sm171 - Where did you get the wiring harness?
2008 1098
Sola Gratis
Old Dec 20th, 2008, 6:00 pm   #9 (permalink)
69jme69's Avatar
try splicing the wires into the rear brake light or like has been suggested hotwire of the battery with an inline fuse ...ive done both in the past
69jme69 is offline   Reply With Quote
Old Dec 20th, 2008, 11:40 pm   #10 (permalink)
sm171's Avatar
Del City. They also have some nice heat shrink connectors.
http://www.delcity.net/store/Weather...er/p_11187.a_1
Mike
08 Ducati HM1100
08 KTM 450 EXC-R
Ducati Electrical Problems Explained JEC Hall of Wisdom 17 May 13th, 2012 11:24 am
Modifying the 7XX/9XX Electrical System Load Shazaam Hall of Wisdom 8 May 1st, 2012 1:57 pm
Gps John Apparel and Accessory Chat 8 Nov 27th, 2008 3:01 am
Autocom and Zumo 550 GPS ... group loop interference :-( TilJ Sport Touring 12 Jul 18th, 2008 10:30 am
