ciao a tutti -
yes, the seat (stock AND dp versions) will wiggle side-to-side, when installed. this is due to the rubber bump stops located on the sub-frame, not being tall enough to contact the seat bottom.
solution: remove seat and install appropriate thickness of adhesive backed neoprene foam tape (found in hardware stores, in the door section, used as door insulation). for my dp seat, it took two strips of this adhesive backed neoprene foam (thickness of neoprene foam is approx. 1/4 inch) stuck on top of each other on each side of the seat bottom.
now, seat is stable ... no wobbles.
if you can't fix it with duct tape (and/or neoprene tape), it ain't worth fixin.
