Wheelies by slipping the clutch: is it not safe? - Ducati.ms - The Ultimate Ducati Forum
Old Dec 10th, 2008, 4:19 am   #1 (permalink)
A mate of mine told me that one should never slip the clutch to pop a wheelie on a dry clutch system.
Is it true?
Marc Polo is offline   Reply With Quote
Old Dec 10th, 2008, 8:31 am   #2 (permalink)
motoxer311's Avatar
ooops... Not sure but I've been doing it..
motoxer311 is offline   Reply With Quote
Old Dec 10th, 2008, 9:09 am   #3 (permalink)
kingsnake1650's Avatar
prolly gonna wear the clutch a little faster....dogging the bike cant be the best thing for it either. If your not gonna dog it why do you have it??
kingsnake1650 is offline   Reply With Quote
Old Dec 10th, 2008, 9:09 am   #4 (permalink)
Lifetime Premium
donkeyman's Avatar
it's certainly easier to flip the bike by clutching it. But that applies to both and wet & dry clutches.
donkeyman is offline   Reply With Quote
Old Dec 10th, 2008, 9:23 am   #5 (permalink)
Thanks a lot for the replies.
I'm used to wheelie by slipping the clutch, I find that I have much more control on the wheelie that way.
Another question:
Is it true that the Desmodromic engine could eventually seize because of popping long fat wheelies? Apparently the oil get stuck at the back because of the way the bike is inclined while the front end is pointing up? Any truth, or is it just another pub story?
Old Dec 10th, 2008, 9:39 am   #6 (permalink)
The main concern is blowing oil out the crank breather valve during extended wheelies. There are mods you can make to prevent that if you're a wheelie monster...
Old Dec 10th, 2008, 9:41 am   #7 (permalink)
Duc ... Duc ... GOOSE!
Da_Bull's Avatar
Past Ducatis have had issues with oiling due to the location of the pickup in the sump. This has been "rectified" in recent past and you should have no problems.
Watch out, though, because extended wheelies will pump oil into the airbox and turn your bike from a Hypermotard into a Hyperchimney.
-Marco
Da_Bull is offline   Reply With Quote
Old Dec 10th, 2008, 10:39 am   #8 (permalink)
motoxer311's Avatar
That's what I heard..
Old Dec 10th, 2008, 11:55 am   #9 (permalink)
08hyper's Avatar
Popping the clutch to do wheelies, is no different to a wet or dry clutch,
as they are both the same mechanism, so "POP" away! Aloha Alex
Old Dec 10th, 2008, 12:37 pm   #10 (permalink)
Chilehead
st2lemans's Avatar
Images: 74
None of mine need to pop the clutch to do a wheelie.
Personally, I am proud of the fact that I never wheelie except when powering out of corners in the mountains.
It's called self control.
Tom
1985 LeMans
1986 LeMans w/ sidecar
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
st2lemans is offline   Reply With Quote
01 996 Clutch slipping flamesofvengeance Superbikes 1 Jun 22nd, 2008 2:51 pm
The dreaded clutch question again Corse1 Sport Touring 23 Apr 13th, 2008 7:38 pm
strange sensation ... clutch slipping? sdh Supersport 4 Jan 25th, 2008 10:00 am
felt clutch slipping this morning gehadbusher Sport Touring 2 Dec 4th, 2006 4:22 pm
slipping clutch supersparky750 Supersport 1 Aug 1st, 2006 12:22 pm
