Tail piece broken? - Ducati.ms - The Ultimate Ducati Forum
Old Dec 10th, 2008, 4:15 am   #1 (permalink)
Tail piece broken?
Hi everyone,
The upper plastic tail piece of my Hypermoto seems to be broken, as it's quite loose over the tail light.
There is a little white plastic clip that might be broken... Is it common? Any remedies?
Grazie mille!
Marc Polo is offline   Reply With Quote
Old Dec 10th, 2008, 6:11 am   #2 (permalink)
alounacara's Avatar
Thumbs up
I dont know if it is common but ck your horn bolts because mine almost fell off the other day when i was slipping my clutch doing a wheelie
2008 Hypermotard
1994 ZX9R Kawasaki gone and good riddance
Houston Texas
alounacara is online now   Reply With Quote
Old Dec 10th, 2008, 11:59 am   #3 (permalink)
08hyper's Avatar
Originally Posted by Marc Polo View Post
Hi everyone,
Grazie mille!
I broke 2 of them, its a warrantee issue, the little clip under the tail breaks off, Aloha Alex
Old Dec 10th, 2008, 12:05 pm   #4 (permalink)
johnchypermotard's Avatar
ciao fratello -
there are two plastic flag bosses on the tail piece cove ... remove the seat, remove the small allen screw that secures the tail piece cover, then gently push the cover forward to remove it. once off, look to see if the flag bosses are intact. if they are, then carefully slide the cover back into place, making sure the flag bosses are positioned correctly, then screw the allen screw in place.
of course, if the flag bosses are broken, take the part to your dealership to have it replaced under warranty, then install the new one carefully.
a presto,
johnc
Old Dec 10th, 2008, 1:33 pm   #5 (permalink)
mine broke when i took it off probably. can't be arsed to fix it tho as its not slowing me down and its not going to fall off. double sided velcro would be the best fix as the tabs will just break again
Old Dec 10th, 2008, 2:02 pm   #6 (permalink)
ham fisted antipod
Old Dec 10th, 2008, 3:32 pm   #7 (permalink)
i think 3 of mine are broke off and the others almost. There is white plastic dust all under mine tail piece from where the plastic rubs the black tail light piece. They break because of the vibrations from the bike. I dont know if this is a warranty fix or not
2008 HM-1100
2007 ZX-10R-sold
supermoto292 is offline   Reply With Quote
Old Dec 10th, 2008, 11:12 pm   #8 (permalink)
AXE
AXE's Avatar
Mine were broke within a few months or riding. I haven't asked my dealer about it, since it doesn't seem to be affected, except is sits a little higher and not flush with the bottom. I agree, unless the new design is better, some velcro or double sided tape would be a better fix.
Out!
2008 Ducati Hypermotard
Old Dec 11th, 2008, 1:12 am   #9 (permalink)
Thanks a lot for your replies.
So it's a common problem...
Old Dec 11th, 2008, 7:18 pm   #10 (permalink)
Originally Posted by johnchypermotard View Post
ham fisted antipod
did someone say ham??? Hmmmmm ham.... <dribble>
I'd say a gentle tug whilst trying to see how it was held on, its s shit house design that was never going to last. I bet a dealer couldn't get it off without breaking it. they break everything else.
Broken R&G Tail Tidy !!!! hyprduc HyperMotard 18 Apr 18th, 2009 11:33 am
1098 Tail Piece Removal GeneS Superbikes 2 Nov 13th, 2007 9:47 pm
Removing mono tail piece? Yellow749s Superbikes 4 Oct 2nd, 2006 10:58 pm
Tail Piece identification? Gunzen Supersport 0 Sep 16th, 2006 4:44 pm
