Power Commander Install? - Ducati.ms - The Ultimate Ducati Forum
Old Dec 6th, 2008, 6:39 pm   #1 (permalink)
AXE
AXE's Avatar
So I got my Power Commander and am planning on installing it, so I can get it back on the dyno. This thing is much larger than I thought. Where are you guys installing this thing? I am assuming up in the side fairings. Thanks!
Out!
2008 Ducati Hypermotard
Old Dec 6th, 2008, 6:49 pm   #2 (permalink)
alounacara's Avatar
Thumbs up
I mounted mine on the bars, It keeps the front end from wobbling
2008 Hypermotard
1994 ZX9R Kawasaki gone and good riddance
Houston Texas
alounacara is online now   Reply With Quote
Old Dec 6th, 2008, 7:28 pm   #3 (permalink)
kingsnake1650's Avatar
LOL isnt it nice when people are so helpful.
It has to go back by thre battery
kingsnake1650 is offline   Reply With Quote
Old Dec 6th, 2008, 7:42 pm   #4 (permalink)
parkcrf's Avatar
Randy,
Mount it in the glove box where the tools are stored in the right or left shroud. Thats where mine is and where my delaer installs it. Use zip-ties
Current Stable:
2008 HYM 1100
2008 RXV550
2007 CRF450
2001 CR250
Old Dec 6th, 2008, 8:27 pm   #5 (permalink)
Monstaman's Avatar
WOW ... a powercomandamper, technology is well cool these days
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Dec 6th, 2008, 10:47 pm   #6 (permalink)
garbagetruckdriver's Avatar
Mine is under the seat on the left, next to the battery.
garbagetruckdriver is offline   Reply With Quote
Old Dec 6th, 2008, 11:34 pm   #7 (permalink)
hyprduc's Avatar
mine too. Under the seat on the left side of the battery. Fits nice there and that's what the instruction suggest.
hyprduc is offline   Reply With Quote
Old Dec 7th, 2008, 1:13 am   #8 (permalink)
If you mounted in the front you would have to run a long wire back to the battery, and the wires going to the TB's would be too long.
Old Dec 7th, 2008, 1:39 am   #9 (permalink)
alounacara's Avatar
Thumbs up
You can zip tie it to the kickstand also
2008 Hypermotard
Houston Texas
Old Dec 7th, 2008, 11:24 am   #10 (permalink)
AXE
AXE's Avatar
So did you guys notice any noticeable power increases, throttle responsiveness, etc. after you PC install?
The tech told me I was a tad lean across the board with my full Zard system, DP ECU, DP air lid, and DNA filter. It seems to perform just fine and laid down an nice curve on the dyno. I hope the PC is worth the additional $270. This is my first FI machine, so the PC is new to me.
I finally pulled it from the packaging. It definitely looks like you need to install it close to the battery as the lead is only about 6" long.
Out!
power commander and red key query Shalei Superbikes 2 Feb 29th, 2008 5:41 am
power commander settings manny900ss Supersport 2 May 14th, 2007 9:08 am
Do you think they will make a power commander for the 1098? racecomp Superbikes 11 Feb 28th, 2007 3:43 pm
power commander map jono_1uk Superbikes 12 May 22nd, 2006 11:31 am
Power Commander for a 916 John Superbikes 3 Jan 12th, 2006 2:19 am
