Exposed Battery - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearGraves MotorsportsMotorcycle.com
Old Dec 6th, 2008, 8:58 am   #1 (permalink)
Natoravar's Avatar
Question Exposed Battery
After i bought the bike i noticed the battery is exposed to everything underneath the bike . I run the 2-1 full termi system. I removed the seat and noticed the battery is completely lose, no casing or even a band holding it. Now the question i have is there anything i can install to hold the battery and something to protect it?
Thanks in advance.
Natoravar is offline   Reply With Quote
Old Dec 6th, 2008, 9:26 am   #2 (permalink)
sconly's Avatar
there is a heavy foam block attached to the seat that helps hold the battery in place.
sconly
www.NEDR.org for riders by riders
sconly is offline   Reply With Quote
Old Dec 6th, 2008, 9:36 am   #3 (permalink)
There is a bracket to hold the battery down, take it to your dealer and they will install it for free as I believe this was an early recall.
F-
Ferrell75002 is offline   Reply With Quote
Old Dec 6th, 2008, 10:26 am   #4 (permalink)
Caidly's Avatar
Build Years/Makes/Models: 2008 DUCATI HYPERMOTARD
Units affected: 385
Recall Number: 07V474000
Summary: ON CERTAIN MOTORCYCLES, THE BATTERY CAN MOVE SIDE TO SIDE INSIDE THE FUEL TANK MOUNTING COMPARTMENT. THIS MOVEMENT COULD RESULT IN MAIN WIRING HARNESS DAMAGE AT THE BATTERY TERMINAL. THIS CONDITION COULD CAUSE AN ELECTRICAL SHORT CONSEQUENTLY STOPPING THE ENGINE.
Consequence: IF THE ENGINE STOPS WHILE THE MOTORCYCLE IS BEING DRIVEN, IT COULD INCREASE THE RISK OF A CRASH.
Remedy: DEALERS WILL INSTALL A BATTERY MOUNTING BRACKET AND TWO DOUBLE LOCK VELCRO STRIPS ON THE BOTTOM OF THE BATTERY. THE MANUFACTURER HAS NOT YET PROVIDED AN OWNER NOTIFICATION SCHEDULE. OWNERS MAY CONTACT DUCATI MOTORCYCLES AT 1-408-253-0499.
Notes: CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
if you need to know... ask...
Old Dec 6th, 2008, 6:01 pm   #5 (permalink)
Natoravar's Avatar
Thanks everyone. I went for a ride today, and i experienced almost everything the recall explains, didnt crash but had more than one oh shit moments. Went directly to the dealer and they installed the bracket in 5 min. What was happening was that the movement and vibration of the bike and the battery wire being stiff made the screw become loose, it was very scary to control the bike in the middle of a turn and the engine dying
How To: Install an Odyssey PC680 Battery in your 1995-2002 Superbike! mpaschetto Superbikes 26 Sep 2nd, 2010 8:10 pm
Battery Blues, and DUCATI Electrical Stick Hall of Wisdom 15 Nov 14th, 2009 7:01 pm
Bikemaster BTZ7S Lightweight Battery SAC Superbikes 3 Nov 22nd, 2008 9:43 pm
Dead Battery St3 whenisell Sport Touring 21 Jun 12th, 2008 1:29 pm
!!!! Possible Gas Tank / Battery Damage!!!!!! 08hyper HyperMotard 13 Jan 15th, 2008 1:23 am
