S front brake vibration/sound - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearGraves MotorsportsMotorcycle.com
Old Dec 5th, 2008, 12:06 pm   #1 (permalink)
When you hit the front brake real hard it sounds like a garbage truck's brakes.
Just before you are dead stopped.
Slight vibration is felt and a howling sound not a squeal is heard.
This is not the sound of the vents cut in the disc.
Any ideas?
overdog is offline   Reply With Quote
Old Dec 5th, 2008, 12:15 pm   #2 (permalink)
I hope someone has some idea's. I have the same noise problem but not the vibration. I have done everything to the brakes, except change the pads. So, maybe i should do that ??
F-
Ferrell75002 is offline   Reply With Quote
Old Dec 5th, 2008, 12:33 pm   #3 (permalink)
brakes
mine does the same thing. very annoying!
1950 Triumph T-Bird
1954 Triumph T-Bird
1961 Triumph TR6
1969 Triumph Bonneville
1973 Triumph TR5 MX
1969 Harley FLH Shovelhead
2006 Honda CRF 250F
2008 Ducati Hyper 1100S
1969 Meyers Manx Buggy
nog00der is offline   Reply With Quote
Old Dec 5th, 2008, 1:17 pm   #4 (permalink)
Mine does the same thing. A loud howling sound just before I come to a stop. I'd really like to get it figured out as well.
breakdown is offline   Reply With Quote
Old Dec 5th, 2008, 1:46 pm   #5 (permalink)
mine too
I have the same issue with my left front rotor....while braking hard, getting the garabe truck vibration howl from the rotors. not sure what the issuse is? anybody have any ideas how to resolve this issue..
herbdon out..
08 Black HyperMotard 1100s
HerbDon is offline   Reply With Quote
Old Dec 5th, 2008, 3:50 pm   #6 (permalink)
same here. I'm going to swap pads.
hbliam is offline   Reply With Quote
Old Dec 5th, 2008, 4:10 pm   #7 (permalink)
Banned
A little high temp silicone on the back of the pads should take care of it.
Old Dec 5th, 2008, 4:13 pm   #8 (permalink)
lelenb's Avatar
Images: 12
I found that the majority of the sound was radiating from the carbon fiber front fender. I removed the screws and installed rubber washers between the posts and the fender and the sound was eliminated. Just tap on the fender with your finger tip and you will most likely hear it rattle. The screws bottom out before they fully contact the fender and the plastic washer. Try this first before trying something more complicated, plus it will on cost about a dollar for rubber washers. If you are in CA you can get them at OSH.
Lelen
Hyper S
Old Dec 5th, 2008, 6:38 pm   #9 (permalink)
johnchypermotard's Avatar
apply a thin coating of silicon spray on the rotors ... stops the squealing right away.
of course, the brakes cease to work ... but at least the darn squealing is gone.
legal notice: johnc's suggestion above is a JOKE. DO NOT attempt to apply silicon spray on the rotors of your bike (or car), as DEATH may result.
Old Dec 5th, 2008, 6:43 pm   #10 (permalink)
garbagetruckdriver's Avatar
I get the same annoying noise - but it goes away after a good thrashing at the track. Usually takes about a day of city riding to come back again.
garbagetruckdriver is offline   Reply With Quote
Soft front brake davemcqueen Superbikes 3 Jan 20th, 2008 10:29 pm
HM Front Brake Survey Motard-Menace HyperMotard 13 Jan 12th, 2008 4:03 pm
Cycle cat & Front brake reservoir PAST2 Sport Touring 13 Jul 27th, 2007 6:50 am
Looking for source for ST3S front brake rotor Memphis675 Sport Touring 9 Apr 21st, 2007 9:32 am
Two-up, front brake misbehaving on ST3 pitchow Sport Touring 5 Mar 9th, 2007 8:13 pm
