HOT Hyper - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGearGraves MotorsportsMotorcycle.com
Old Dec 4th, 2008, 9:20 pm   #1 (permalink)
HOT Hyper
While riding my new Hypermotard today in Tucson traffic, the temp climbed to 266F and the bike stalled. I am new to Ducati and to air cooled in general. Is this considered hot for this bike? I know there is a stalling issue due to emissions and ECU in warm weather but how hot is hot for the Hyper. It only has 350 miles on it. Any help would be great. Thanks
Hyper55 is offline   Reply With Quote
Old Dec 4th, 2008, 9:41 pm   #2 (permalink)
GMP
The stalling is not normal but the temp is, for a stock bike. It gets a little better with more miles, but the richer mixture from a DP ECU will drop the temp as much as 30 deg in the same conditions.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Dec 4th, 2008, 9:43 pm   #3 (permalink)
alounacara's Avatar
Talking
I refuse to sit in traffic with my new Hyper so ive never had a overheat problem, I live in Houston and it gets pretty damn hot here
I cut thru traffic like a hot knife thru butter, Try it you will like it
It is air cooled engine so you cannot sit still idleing for an extended time
2008 Hypermotard
1994 ZX9R Kawasaki gone and good riddance
Houston Texas
alounacara is online now   Reply With Quote
Old Dec 4th, 2008, 9:53 pm   #4 (permalink)
AXE
AXE's Avatar
I have seen temps around that range, but never had any stalling issues. You may need to tweek you fuel settings. The dealer should be able to do this for you..............maybe under warranty.
Out!
2008 Ducati Hypermotard
Old Dec 4th, 2008, 10:24 pm   #5 (permalink)
the bike is still tight ( wont be run in till at least 1000 miles).Mine did the same at 600 km. Lots of threads on stalling ( if the problem continues).Standard ECU ( esp US version) is lean- buy Jasons Fatduc o2 sensor manipulator.
just my 2c
jonathan
Old Dec 5th, 2008, 6:18 am   #6 (permalink)
I have seen 260 going flat out ( not mph), the oil temp warning light won't even come on before reaching around the 325 degree mark so you issue was not related to the temperature.
www.Shift-Tech-Carbon.com
Shift-Tech-Carbon Performance- High Quality Carbon Products!
Shift-Tech is offline   Reply With Quote
Old Dec 5th, 2008, 1:24 pm   #7 (permalink)
Home of vortex tuning
CDONA's Avatar
For stalling, open the air bleeds, for temp, mine stock ran up to 250 from Cottonwood to Flag (I 17) last July until the elevation cooled a bit. The o2 manipulator works for me now, dropped temp 15 to 20 degrees, and still get 115 miles or better before the fuel light.
Old Dec 7th, 2008, 5:26 pm   #8 (permalink)
sick50ford's Avatar
thats hott
Old Dec 7th, 2008, 5:29 pm   #9 (permalink)
sick50ford's Avatar
lets try that again,
thats hot!
Old Dec 7th, 2008, 7:03 pm   #10 (permalink)
Images: 14
my bike was running pretty lean when I picked it up from the dealer, I took it back in a week later and they tweaked the air bleeds and sorted out the tps. Bike runs cooler now and the headers glow a lot less. I saw those same temps when I first picked up the bike. I don't see over 230F now, even sitting at stop light to stop light traffic.
I don't know about NJ, but I know AZ prohibits lane sharing and lane splitting. I never got a clear answer if the carpool/HOV lane in california can be shared, ie passing cars on the right when the carpool/hov lane is going slow or isn't moving.
vapor is offline   Reply With Quote
hyper summit point track day freezer16801 HyperMotard 4 Sep 3rd, 2008 11:16 am
Thoughts After 1 week on the Hyper Treadmarks HyperMotard 7 Aug 15th, 2008 1:42 pm
Anybody have (or had) a Multistrada? How did it compare to Hyper? josephvman HyperMotard 14 Jul 19th, 2008 6:58 pm
new hyper s running hot dctech7 HyperMotard 15 Jul 14th, 2008 1:13 pm
Multi vrs Hyper bromike666 Multistrada 31 May 28th, 2008 2:11 pm
