1100S Suspension - Spring Replacement Question - Ducati.ms - The Ultimate Ducati Forum
Patriot Powersports
Old Dec 2nd, 2008, 7:34 pm   #1 (permalink)
GNGYoung's Avatar
Gents,
I've had my Hyper now for a while and have made the time to set up the spring sag for the front and rear. The Ohlins site says the front rider sag should be set to 35-50mm and the rear rider sag should be set to 25-40mm. You can see this for yourself at : http://www.ohlins.se/Motorcycle/Sett...9/Default.aspx
I"m a big man at 6'4" and 260+ pounds and have achieved 50mm front and 39mm rear rider sag. I did this by increasing the rear preload by four full turns and increasing the front preload by one full turn. I figure the Hyper was meant for a 185 Lb man and sprung accordingly at the factory. I'm told by a local Pro suspension shop (they do all brands/types of bikes) that the Ohlins and Marzocchi springs can be replaced with heavier OEM ones for about $199 CDN for the front and $159 CDN for the rear) and that this will set the sag to 25mm rear and 35mm front.
Does anyone have any experience with changing the springs? If so, what did it do for the bike? Does it ride stiffer? Did it really make a difference? If so, what did you notice in the turns/bumps? I'm sure for an experienced track rider it would be noticeable, but am I really going to see much of a difference for my riding? I enjoy tooling around town and being a general nuisance on the country roads. ( I love this thing - they should have called it the HyperREtard !!)
Thanks in advance!
G
Gord
08 HYM 1100S
GNGYoung is offline   Reply With Quote
Old Dec 2nd, 2008, 11:53 pm   #2 (permalink)
AXE
AXE's Avatar
You probably would benefit from stiffer springs given your size. However, don't expect the sag up front to be similar to sportbikes. This thing essentially has a long travel front suspension like a dirt bike and sagging in the low to mid 40s is typical. I try to get the sag set so the bike is relatively level when riding on smooth flat terrain.
There are a lot of threads on suspension setup and tuning, including springs if you do a bit of research on this forum.
Out!
2008 Ducati Hypermotard
Old Dec 3rd, 2008, 7:22 pm   #3 (permalink)
freezer16801's Avatar
I don't believe there is a replacement spring for the forks yet. Many of us just change out the fluid to lighter fluid to get rid of some of the harshness. Those who have aleady changed the fluid have noticed more fluid than the service manual recommends. Therefore with too much fluid and too high of a viscosity, the forks are too harsh no matter how you fiddle with the adjusters.
The Marzocs don't even permit a compression or rebound shim change because the cartridge is crimped. I plan on changing out the fluid this spring. I guess the only other thing I can do is get replacement cartridges from racetech.
08 Ducati HM
03 Yamaha R6 track bike
02 Suzuki TL1000-R RIP baby
Old Dec 3rd, 2008, 7:38 pm   #4 (permalink)
Monstaman's Avatar
Info on Marzocchi is very sparse at this point, I don't know if they are trying to keep it a secret however none of them have been forthcoming with info to help decide at least what I wanted which is lighter springs.
I am having springs made at present to suit me.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Dec 3rd, 2008, 8:00 pm   #5 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Posted this elsewhere a while back... but Jim Lindemann has heavier springs (.92) and can modify the adjusters to improve fork action. About $215. He can also revalve the Ohlins on the rear.
http://www.le-suspension.com/
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Question about brake master cylinder replacement gcardamone Superbikes 3 Apr 21st, 2007 12:12 am
Clutch replacement - parts question dragknt Superbikes 10 Apr 10th, 2007 12:01 am
Replacement Spring for 916 sfzobie Superbikes 1 Mar 15th, 2007 12:09 pm
ST3s ABS ECU and replacement muffler question charlieST3s Sport Touring 2 Feb 15th, 2007 9:44 pm
question about brake replacement dpm Sport Touring 0 Oct 11th, 2006 5:34 pm
