Nov 30th, 2008, 5:23 pm
My ( very limited) experience with the VDST-S
As is the way with forums, I feel compelled to share my new experience- or should I say , force my new experience on you lot.
After waiting 5-6 weeks for all the bits to arrive , I installed the Ducati ECU ( for the 2-1), cut a hole in the airbox lid ( and then rode it for a week- without resetting the ECU, needless to say it had the fuel light on at 100km , not the ususal 180), the the LV cat elim and pipes came , so put them on , then finally last Friday , the VDST arrived.
I must say, I think the LV pipes look the best out of all of them.The only install hiccup was getting the LHS CF cover to 'fit'.
The setup of the VDST was easy. I have a MacBook running Parallels, so installed the latest version of VDST-S, put in the driver for the Belkin serial-USB cable , and fired it all up.
Guess what? It f'n worked first time- unbelievable.
Reset the TPS, and started fiddling with the fuel trim.Needless to say, before resetting the TPS ( and using the DP ECU) , the plugs were charcoal.Surprised the bike ran.
Started at +6, no popping, plugs clean,idling well. So I fiddle, and go to +12.Now have black plugs.
Back to +6, idle hanging a bit ( so turn out the idle air mix screws a quarter), now runs great.
Although the cable ended up being pretty expensive ( about 400 A by the time I'd got it) , it has paid for itself already , and I dont have the inconvenience of going to the dealership.
Unfortunately , I've now done all I can think of to the bike-what will I do with my time now.Maybe have to spend it with my wife and kids....
So, anyone in Sydney who needs to use it , feel free ( all you'll need to do is download the software and I'll lend the cable.)
out
jonathan
Nov 30th, 2008, 7:56 pm
out
jonathan
Nice write up... When you adjusted the fuel trim how far did you ride it in between checking the spark plugs? Did you do a run that put a load on the engine for a while, or go for a short spin?... I'm thinking of doing the same as you did since I just did the Termi 2-1 install this week end... but I figure the dealer could do it better than me... but I don't know...
Nov 30th, 2008, 8:44 pm
thanks.
no, gave it decent go- at least 30 mins.
other than EGO analyser, I reckon between you and this place you can do it easy.
I also think, unless you have a great mechanic, you take more care with your own stuff.
plus its good fun ( and more convenient) to do it your self.
jonathan
Nov 30th, 2008, 10:00 pm
yeah mate.. good news that its all running good. I need to pull a plug and check it out to tweak mine, bit it is way better now i sealed the exhaust correctly with gunk, temp has dropped prob 10deg because of it and the first bend isn't blue any more.
pm me your number and I'll give you a bell when I've got some time.
Pete
Dec 1st, 2008, 8:18 am
I'm surprised that you cured a "hanging idle" by going out on the airscrews, as that is usually associated with a lean condition. If you go with a K&N or other free flow filter you will likely want to trim a bit richer. Remember you are now open loop and there is no compensation except air temp and pressure (altitude). I have the exact same setup and trim at +12, runs perfect.
I had the same minor issue with the left side panel. I removed the bumper from the pipe, and used a piece of high temp silicone rubber tape for insulation. That let the panel sit a little closer and solved the problem. I really like the LVs, quiet enough at idle to fire up in the AM for a ride to work, but they roar when your on the gas and sound awesome at a 4 - 5K RPM cruise.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Dec 1st, 2008, 5:16 pm
re vdst
you are quite correct! Going out on the screws made it worse!They were at 1 full turn out before ( standard ECU,Fatduc O2 sensor manip), now they are at 1/2 turn plus a bit.Seems to idle reliably but a bit 'lumpy'.Doesnt stall.
I'm still fiddling with the fuel trim- was at 6 , still had some soot in the tail pipe, so reset to 4 this morning.Fuel economy a fair bit worse on 6 ( 180->150 km before light) , but I think I'm probably spending more time on the gas!
The plugs on +4 have looked good ( light tan) , so I figured I could lean out a little given the tail pipe soot.
The idle is now rock solid at 1300 ( before it wandered between 1250-1400).
Wondering whether I should invest in a dyno run , just to make sure the AFR's are OK.Or do you think if the plugs etc are OK , then I'm fine?
Thanks again for all your help.Oh, still got standard air filter but the free DP airbox lid ( ie 2" hole saw)
jonathan
oh, when you say bumper do you mean the welded on metal bracket or the rubber grommet that goes in it? I was considering removing the metal bracket , but I forced the side cover( I know, I know....at least I didnt use a hammer)
