would these be the ones to use, correct fitment? could you use all existing kit, brakes yokes etc, just a simple swap in?
supermotard
http://www.superbiketoystore.com/spo...rks/p_166.html
- based on the 48mm MX front fork (MXF)
- total length of 910mm and stroke of 255mm
- hydraulic bump stop
- 2-way base valve (high & low speed compression adjuster)
• Supermotard version available with less wheel offset and shorter total length.
