ecu set up help - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Nov 27th, 2008, 3:31 pm   #1 (permalink)
sick50ford's Avatar
ecu set up help
just installed dp ecu 308b and was playing with the vdst software. anyone set this up know what to do at this point? what to change? what to reset? trying to set up for the following- drilled airbox, k&n filter, complete zard collectors, no 02 sensor, no flapper, stock silencers. any help would be appreciated. trying to stay away from the dealer. thanks
Old Nov 27th, 2008, 3:56 pm   #2 (permalink)
sick50ford's Avatar
reset the vst and service light, but the service light is staying on? after a trip around the block i have engine light with trouble code 36.0 -speed sensor?
Old Nov 27th, 2008, 5:30 pm   #3 (permalink)
the CEL or the Service "wrench"?
all you have to reset is the TPS.
Old Nov 27th, 2008, 6:57 pm   #4 (permalink)
GMP
Make sure you have the latest version VDST. Some versions had a bug with the service indicator reset. You can download the current version from the Technoresearch site.
I'd disconnect the battery for an hour, reconnect, hook up the laptop, and then establish comms with the ECU. Reset TPS, service indicator, and clear any codes. Start the bike and when it reaches about 165 deg F you can adjust the trim. With stock cans start with the trim around 5, should be very close. Good Luck.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Nov 27th, 2008, 7:03 pm   #5 (permalink)
sick50ford's Avatar
thanks, i'll try it!
NEMESIS 749-999 848-1098 ECU --in stock moto Motowheels 6 Nov 12th, 2009 6:45 pm
Dyno results with bad ecu and slipons uzirider HyperMotard 4 Sep 19th, 2008 9:37 am
2001 SS900ie - Exhaust + ECU question DucFanDan Supersport 9 May 7th, 2008 10:07 am
15M ecu - help! dirkwrong Ducati Motorcycle Chat 7 Mar 28th, 2008 7:46 am
powercommander, rapidbike, techlusion, DP ECU, or ultimap? stlouisrider Sport Classic 5 Mar 14th, 2008 9:36 pm
