Going to install the 2 into 1 this weekend.. - Ducati.ms - The Ultimate Ducati Forum
SportbikeTrackGear
Old Nov 27th, 2008, 11:57 am   #1 (permalink)
Going to install the Termi 2 into 1 install hopefully this weekend...After the install is it rideable since I don't have the VDST to TPS reset, or should I truck the bike to the shop before riding it and have them do the reset and any adjustments?
Thanks for any info.
Old Nov 27th, 2008, 1:44 pm   #2 (permalink)
sinex's Avatar
Be great if you could take and post a series of photo's of the instalation,
sinex is offline   Reply With Quote
Old Nov 27th, 2008, 2:39 pm   #3 (permalink)
I'm jealous.
STICKER is offline   Reply With Quote
Old Nov 27th, 2008, 2:48 pm   #4 (permalink)
EarthBM's Avatar
so you are first man, mine is still in the box. Have exact same question about TPS, someone pls answer...
EarthBM is offline   Reply With Quote
Old Nov 27th, 2008, 7:11 pm   #5 (permalink)
GMP
TPS should be pretty close, mine started right up and ran OK. If its a new ECU the trim may be defaulted to 0 which is lean from my experience, but no worse than the stock closed loop setup. If it starts and runs with no major problems its good enough to ride to the dealer.
Glenn
'08 Ducati Hypermotard 1100
'07 GasGas EC250
Old Nov 28th, 2008, 2:20 am   #6 (permalink)
i'd be glad to take pictures of the install for you, but the pdf instruction picts do a pretty good job from what i see.... do you have the pdf instructions? if it will help i'll document my install .let me know
earthbm...yeah i'm going to do it, but i dont need to...the bike is great as it sits... 6 hp, and some wieght savings isn't going set the world on fire...but it will look cool and i've heard throttle response is smoother...i'm tired of looking at this box in my garage is the main reason..
Converti bar install on a ST Gary02ST4S Sport Touring 10 May 28th, 2008 9:31 am
916 HID Install w/ photos goduke Superbikes 9 Jun 16th, 2007 7:12 am
Anyone done the Termi install themselves? bongoboyla Sport Classic 4 Feb 11th, 2007 8:31 pm
