Nov 25th, 2008, 2:24 am
2-1 vs. 2-2 Termi weight savings
On the Ducati website, they claim 7kg weight savings for the 2-1 Termi racing kit.
If I choose to get the Full Kit with 2-2 carbon Termi's, what will my weight savings be if any?
Nov 25th, 2008, 3:03 am
+1
Or if someone knows the weight of the 2in2 exhaust?
2008-07: Hypermotard 1100s Black (~98whp)
Nov 25th, 2008, 5:51 am
Originally Posted by wjn
+1
the slipons weigh about as much as the stock exhaust
Nov 25th, 2008, 6:28 am
 And that is?
I did see some (titanium) slipons weighing about 3 kg (about 6.6 lbs), maybe I go for function instead of looks.
Nov 25th, 2008, 9:28 am
 And that is?
Hey, there's an idea...
Nov 25th, 2008, 9:34 am
(-) the weight of the servo motor, cable and flapper valve.
TREADMARKS
Ford F150 4x2 Lifted
Nov 25th, 2008, 11:24 am
the Termi slipons are not carbon. they are carbon wrapped. someone on the forum weighed the stock cans vs. the Termi slipons and the Termi's were heavier (IIRC).
If you remove the cat, flapper, flapper motor and cables, you'll lose a little more weight.
Nov 25th, 2008, 1:17 pm
From std header/cat/valve/flapper and cables to Zard replacement ... i.e everything bar the slipon you will save 3.5 kg, I don't know the difference between the stock and Termi slipons though sorry.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Nov 25th, 2008, 8:30 pm
I have a full stock system i coan weigh. I did not weigh my 2-1-2 system before fitting it. The main reason i went for the 2-1-2 system was crash protection - none of the aftermarket exhaust sytems for the hyper are cheap. I wanted something that would not need to be replaced after a minor off.
Hypermotard 1100S
Aprilia SXV550
Aprilia RS250
Suzuki RGV250
Nov 26th, 2008, 12:45 am
I dunno what you consider cheap but my Quat-D full system costs about $1060.00: http://www.motowheels.com/italian/my...rcycle%20Parts
Also I weighed each piece on a scale:
Quat-D Full System Installation Review and Pics!
The stock cans weigh 11LBS, I am sure the aftermarket can do better than that.
08' HyperMotard- Quat-D Full Exhaust System, DP ECU, Blinged Clutch, DP WindScreen, DP Comfort Seat, err and some sliders...
