ST2 98 Zero tension in clutch lever - Ducati.ms - The Ultimate Ducati Forum
Graves Motorsports
Old Nov 23rd, 2008, 10:14 pm   #1 (permalink)
After adding some dot 4. shell brake fluid into the clutch reservoir, I pumped the clutch lever a few times, wiped the spurt out of my eye, replaced the rubber filler and lid of reservoir and found that I had zero tension in my clutch. None. Nada. Where did I go wrong? And more to the point, what happened! Bike getting collected to go into workshop, and I'm furious. All I did was simple home maintenance. Why did the tension go like that?
"Never ride faster than your guardian angel can fly"
dukegrrl is offline   Reply With Quote
Old Nov 23rd, 2008, 10:50 pm   #2 (permalink)
AXE
AXE's Avatar
I think you got some air in the system. You are gonna have to bleed the system again. There are a number of threads on bleeding a Duc clutch, just do a search.
Out!
2008 Ducati Hypermotard
Old Nov 23rd, 2008, 11:24 pm   #3 (permalink)
08hyper's Avatar
Yep, you sucked AIR......and that SUCKS! Aloha Alex
New Clutch, Decisions, Decisions ... Shazaam Hall of Wisdom 6 May 19th, 2011 9:00 am
Clutch Lever Disassembly Question Motophoria Sport Touring 2 Jun 26th, 2008 6:37 pm
CRG Clutch Lever Install Tips duc808 Superbikes 1 Mar 18th, 2008 9:53 am
How hard can it be to replace the clutch lever socalrob HyperMotard 13 Oct 21st, 2007 10:36 pm
clutch lever assembly daboogah Supersport 0 Dec 14th, 2006 6:15 pm
