De-cat pipe worth 7bhp gain? - Ducati.ms - The Ultimate Ducati Forum
Old Nov 21st, 2008, 1:44 am   #1 (permalink)
sinex's Avatar
Is replacing the cat, with a de-cat pipe worth a gain of about 7 bhp? I am running termi 2-1-2- with the ECU and Air box lid, might add a K&N air filter too,
sinex is offline   Reply With Quote
Old Nov 21st, 2008, 3:06 am   #2 (permalink)
parkcrf's Avatar
It aint the cat removal. I mistakingly spent $1,500 on the DP manifold to go with the slip-ons thinking this would add a few HP. My shop's dyno shows no discernible gain with this mod over just slip-ons with cat
Current Stable:
2008 HYM 1100
2008 RXV550
2007 CRF450
2001 CR250
Old Nov 21st, 2008, 3:37 pm   #3 (permalink)
wjn
wjn's Avatar
Images: 11
It's a common misunderstanding that a cat causes less HP. It's the mapping and other restrictive things which causes this.
2008-07: Hypermotard 1100s Black (~98whp)
wjn is offline   Reply With Quote
Old Nov 21st, 2008, 7:51 pm   #4 (permalink)
infidel's Avatar
[QUOTE=wjn;517639]It's a common misunderstanding that a cat causes less HP.[QUOTE]
Maybe, but it's heavy as shit!
Hypermotard 1100S
Aprilia SXV550
Aprilia RS250
Suzuki RGV250
Old Nov 21st, 2008, 8:57 pm   #5 (permalink)
08hyper's Avatar
Good mod!
If you remove and replace the CAT with decat tubes and rehook the O2 sensor, you can run the stock ECU, and you will gain better throttle responce,
a deeper/louder exhaust note, few lbs lighter weight, and between 1/2 to 1 HP increase. Aloha Alex
Old Nov 21st, 2008, 9:21 pm   #6 (permalink)
Treadmarks's Avatar
I have the 2-1-2 ecu(308B), fuel trim set at zero, with a DNA filter in a ported airbox, with a Leo Vince cat eliminator pipe, 02 sensor removed, flapper valve servo motor deactivated and removed with cables, stock cans in place. It is a tad louder at idle, but sounds soo freakin sweet whe you wind it up that you don't want to get off of it.
I don't know what the dyno says, but judging by the teeth marks in my seat, I am willing to go out on a limb and say it's waay better than it was before. The Kyle throttle tube works perfect with this combination for daily driving and navigating traffic in general. Just make sure that it is pointed in a safe direction when you twist the grip, because that last half of the twist covers a whole lot of ground.
Anyone know where I can get a zard penta slipon cheap let me know, cause I get a chubby just lookin at one.
TREADMARKS
Ford F150 4x2 Lifted
Treadmarks is offline   Reply With Quote
Old Nov 23rd, 2008, 11:20 am   #7 (permalink)
AXE
AXE's Avatar
This thread sums up these mods pretty well with some good dyno data.
Hyper on dyno
I think the answer is really a complete change in the intake, exhaust, and fueling (adding supporting ECU). This is going to cost you around $1500-1600 on the low end for a new system. I have the Zard system and a DP ECU and it runs well. It is a reasonable (not great) cost for power, but if you factor in the sound it makes the Ducati a Ducati and well worth the $!
Out!
2008 Ducati Hypermotard
Lv Cat Pipe GEE-BEE HyperMotard 6 Mar 19th, 2008 1:35 pm
