Nemesis ECU for the Hypermotard - Ducati.ms - The Ultimate Ducati Forum
Old Nov 20th, 2008, 7:54 pm   #1 (permalink)
Official Sponsor
desmoworks's Avatar
Nemesis now has a replacement ECU for the Hypermotard. I'll have them available shortly - contact me to reserve yours. Retail is $1250. I'll be doing package deals with this and an exhaust. This is by far- hands down the best option there is. Don't even ask how dyno jet compares as it isn't allowed to be used in the same sentence... seriously
If you don't know what the Nemesis is... check out their website here: http://www.mmcompsys.com/motorsportsengine.html
Basically it allows you to do anything you can think of inside the ECU. Full access to everything! We will be making maps this winter and Nemesis already has some available that will come with the unit.
Here are some of the things the end user can adjust:
Injector ‘dead time’ table (time to open the injector at differing battery voltages) This allows you to change injectors
Coil dwell table for users who wish to change coils
On/off selection for the ‘tilt switch’ input
Full access to the throttle calibration and breakpoint selection
RPM breakpoint selection
Full access to the wide band lambda calibration and breakpoint selection (16 points)
Pre-injection time – mSec of injector open duration at power on to prime the cylinders
Fuel pump timer strategy
Tilt switch strategy
Over run fuel / spark strategy
Temperature activation threshold for left and right cooling fan
Professional ‘flat shift’ strategy
Tyre circumference & trigger teeth calibration
Rev limiters for spark and fuel (no limitations)
Advanced transient strategy for fuel and spark advance with full user control
Advance correction tables for air temp / water temp / horizontal and vertical cylinder / air pressure
Injection correction for tables for air temp / water temp / air pressure
Injection phase angle table plotted against RPM
Horizontal cylinder injection table in mSec with 32 x RPM and 20 x Throttle breakpoints
Vertical cylinder injection table in mSec with 32 x RPM and 20 x Throttle breakpoints
Spark advance table in degrees with 32 x RPM and 20 x Throttle breakpoints
Injection correction table as a function of speed with 32 x speed and 20 x Throttle breakpoints
Advance correction table as a function of speed with 32 x speed and 20 x Throttle breakpoints
Cranking correction (cold start map) with 32 x engine rotation and 20 x temperature breakpoints
Your map may be loaded into map 1 or map 2 positions when you upload to the ECU, so the entire map may be different not just a trim.
Target RPM value for cold start and normal running
Anthony Creek
Pro Italia Online || mota-lab
desmoworks is offline   Reply With Quote
Old Nov 21st, 2008, 12:59 am   #2 (permalink)
gee, you could get into a lot of trouble with that baby
Old Nov 21st, 2008, 8:44 am   #3 (permalink)
couchflyer's Avatar
Images: 54
What exhaust is in the package deal?
2008 Hypermotard 1100s
2008 1098
Sola Gratis
couchflyer is offline   Reply With Quote
Old Nov 21st, 2008, 8:50 am   #4 (permalink)
Caidly's Avatar
HOLY F'ING S!
I think I would screw up the bike more than I would help if I started playing inside there- but GREAT option for those well versed in ECU programming.
if you need to know... ask...
Old Nov 21st, 2008, 9:25 am   #5 (permalink)
Official Sponsor
desmoworks's Avatar
Originally Posted by CTarna View Post
HOLY F'ING S!
Just like most things in the moto world - you don't have to know what you are doing to use it - we will send it already setup for what you need so all you have to do is plug it in like the OEM ECU and ride... all the features are just for people who know what they are doing and definitely won't benefit anyone who doesn't know what they are doing
Most people use it just like a DP ECU - plug it in and go! The difference being the maps are better and can easily be adjusted per bike (though again this isn't a general end user thing - you need to have the tools and know-how to tune a bike).
Anthony Creek
Old Nov 21st, 2008, 9:26 am   #6 (permalink)
Official Sponsor
desmoworks's Avatar
For the Hyper we have at our disposal, Termignoni, Arrow (sometimes ), Sil Motor and ZARD all in full systems or slip-ons.
Anthony Creek
Old Nov 21st, 2008, 9:56 am   #7 (permalink)
good stuff!!!
full ECU > piggy back.
Old Nov 21st, 2008, 2:11 pm   #8 (permalink)
Duc ... Duc ... GOOSE!
Da_Bull's Avatar
Ain't that the truth!
-Marco
Da_Bull is offline   Reply With Quote
Old Nov 21st, 2008, 2:19 pm   #9 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
The nemesis is like shooting a mouse with an elephant gun! That's not necessarily a bad thing. Its great that products such as this are finally being released.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old Nov 21st, 2008, 3:12 pm   #10 (permalink)
Official Sponsor
desmoworks's Avatar
I was hoping you'd read that! Good news is the Arrow USA situation is under control and shipments are resuming!
Anthony Creek
NEMESIS 749-999 848-1098 ECU --in stock moto Motowheels 6 Nov 12th, 2009 6:45 pm
DP ECU for Hypermotard interchangable with Sport Classic? garth Sport Classic 7 Jan 12th, 2009 7:13 pm
Hypermotard DP ECU vivaleduc Sport Classic 7 Aug 26th, 2008 11:03 am
Hypermotard stock ECU value? chris410 HyperMotard 9 Mar 9th, 2008 11:04 am
