Front tire cupping... Suspension? - Ducati.ms - The Ultimate Ducati Forum
Old Nov 18th, 2008, 4:13 pm   #1 (permalink)
Lightbulb Front tire cupping... Suspension?
Not my bike...
I ran across a guy with a Hyper S, about 3K miles, and his Corsa III front is quite cupped. He doesn't know why, but I have an idea.
He keeps his tires inflated properly, and he hardly pushes the thing. He's an *older* fellow, and he likes to take it slow and easy, leaving around an inch of virgin rubber on the edges.
So why the cupping? Well, it turns out he's never set up his suspension since the bike was uncrated. The front end is still very soft, and he's around 200 lbs. My theory is that he's using up so much suspension travel in the course of ordinary riding, that the rake is effectively reduced, which causes the front tire to "push", even though he's not even riding aggressively.
I've never had any issues on my Corsa III's (neither has my wife), and I don't recall anyone else having cupping issues that I've read about here.
Later this week, we're going to get his suspension set up and throw a new set of tires on his bike, and we'll see if we can get this thing fixed...
Old Nov 18th, 2008, 7:57 pm   #2 (permalink)
what do you class as cupping?
Old Nov 18th, 2008, 8:05 pm   #3 (permalink)
There's a considerable difference in height between adjacent tread blocks. When you run your hand over the surface of the tire, you can feel the "steps".
The guy says the bike has gotten very twitchy and wiggly as the tire has worn...
Old Nov 18th, 2008, 8:12 pm   #4 (permalink)
that sounds almost 100% like air pressure.... as much as id like to say theres a suspension setup that can cause that.. i have yet to ever find one... no matter what someone tells me about their air pressure...
also, note that if you start to cup a tire, then inflate it properly.. it will continue to cup itself.... at that point the tire is too misshapen for it to not happen...
MrDude_1 is offline   Reply With Quote
Old Nov 18th, 2008, 8:23 pm   #5 (permalink)
The guy runs 32 PSI, which is exactly what I run, and my friend who knows him well tells me he's super anal about that kind of stuff - to the point of checking pressure every single day, which... I mean, come on, I don't even do that...
Old Nov 18th, 2008, 9:03 pm   #6 (permalink)
have a look at the tread. is it worn at 45deg on the front edge with a raised sharp lip on the trailing edge?
Old Nov 18th, 2008, 9:03 pm   #7 (permalink)
Monstaman's Avatar
Just a side thought, has it cupped evenly around the circumference of the tire, maybe balance weights have taken a holiday?
Cupping is also a feature of excessive rebound damping ie allowing packing, just a thought
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Old Nov 18th, 2008, 9:17 pm   #8 (permalink)
Mmm... Yeah, kind of like that, I suppose. Are you getting that, too?
Monstaman, I thought about missing tire weights, too. I'll have a look when I see him later this week...
Old Nov 18th, 2008, 11:22 pm   #9 (permalink)
If the guy is old going slow and cruising as you say the tire isn't even going care at all... It must have been tire pressure intially. My point being if he isn't going fast enough to put some heat and pressure on the tire they won't be effected with cupping unless tire pressure is off. In addition suspension set up is not really important for the most part if a person is going slow... rebound or compression isn't going to help cupping for a person just cruising around... those tire readings that racers go by as far as cupping and stuff are for people on the gas with the bike working hard under them not for and old guy just out for a ride. Probably needs more tire pressure since he is just cruising
Old Nov 19th, 2008, 5:57 am   #10 (permalink)
that wear on the tread is almost certainly too much rebound, wind it right out and bounce it hard till it does 1 rebound only, let him ride it and see how it feels, you can then tweak it on when he needs it.
i just setup my mates front end, he said it transformed the bike. most people seem to run too much rebound damping as it makes the bike feel smooth but it rapes the rubber
Advice to a New Owner Shazaam Hall of Wisdom 9 Jul 12th, 2010 12:51 am
front brake caliper removal for tire change peabs Sport Touring 9 Feb 24th, 2008 7:28 pm
Michelin recall - front tire only SlewofDamascus Superbikes 5 Jul 26th, 2007 7:27 am
Michelin Front Tire Recall axil Sport Touring 0 Jun 21st, 2007 1:24 pm
ST3 --- front suspension improvements Fly Sport Touring 5 Mar 20th, 2007 7:51 am
