seeking pics, Termi 2-1-2 slip/Leo Vin Cat mid - Ducati.ms - The Ultimate Ducati Forum
Old Nov 17th, 2008, 12:38 pm   #1 (permalink)
sinex's Avatar
seeking pics of Termis 2-1-2 slip ons, but with a Leo Vince cat eliminator, reading the threads it would seem the Leo's are a better fitment, agree? any pics of the set up appreciated
sinex is offline   Reply With Quote
Old Nov 17th, 2008, 2:33 pm   #2 (permalink)
johnchypermotard's Avatar
pics / schmics .... just go purchase the termi 2-2 and the leovince cat eliminator. the installation is straight forward ... should take about 3 hours total if you have never done this installation before.
work slow, leave everything loose until you get all the parts installed and bolted into place ... then tighten all the bolts/nuts up.
if you do not purchase the dp mid pipe, then you will be keeping the stock mid pipe with the flapper installed. you can unplug the flapper (or leave it plugged in) and disable it via the display/mode switch, which the termi 2-2 instructions will advise.
you can also remove the lambda sensor, or keep it plugged in, once you move it over to the leovince cat eliminator (if you choose to do so) ... or you can use the bolt/washer combo that comes with the leovince cat eliminator, and remove the lambda sensor from the bike.
so ... just go purchase the parts, plan on a quiet 3 hours to work on it, and post if you have any questions ... we are all here to help.
a presto,
johnc
Old Nov 17th, 2008, 2:38 pm   #3 (permalink)
sinex's Avatar
Already have the 2-1-2 Termis installed, just deciding which cat eliminator to go with, 80% going for the Leo Vince part number 6697 Cat eliminator, previuos threads have indicated its a better fit, but appreciate any pics if someone has some,
Old Nov 17th, 2008, 2:45 pm   #4 (permalink)
here you go ....
instead of the y split mid pipe as shown in pict below, your system will have the leovince cat eliminator connecting to the stock mid pipe.
Old Nov 17th, 2008, 5:22 pm   #5 (permalink)
Eat, sleep, play!
dukepilot's Avatar
Images: 8
Originally Posted by johnchypermotard View Post
here you go ....
That bike looks familiar.
-2008 Hypermotard S
-2005 Buell XB9SX
-2006 Husqvarna SM610
-2004 Husqvarna SM450R
-2004 Husqvarna TE250
-2004 Husqvarna CR125
-2005 CRF170R
Old Nov 17th, 2008, 6:06 pm   #6 (permalink)
yup ... it belongs to a local crackhead
Old Nov 17th, 2008, 6:20 pm   #7 (permalink)
Monstaman's Avatar
..... looks like he is on the right stuff then
dukepilot, I like the way the Leos do the nice crossover, she looks good.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Pics of DP CF side panels for Termi 2-into-1? SpdKlzU HyperMotard 2 Oct 15th, 2008 5:24 pm
Termi Slip Ons parts list or pics? tjg81296 HyperMotard 3 Sep 12th, 2008 3:07 pm
Mid Pipe for Termi Slipon hendricks HyperMotard 7 Mar 20th, 2008 7:42 am
