DIY fitment of De-Cat pipe - Ducati.ms - The Ultimate Ducati Forum
Motorcycle.comSportbikeTrackGearGraves Motorsports
Patriot Powersports
Old Nov 16th, 2008, 12:52 pm   #1 (permalink)
sinex's Avatar
It looks prity simple enough, was it when you fitted yours, any tips, I already have the Termi 2-1-2 & chip and Airbox, would you need the co resetting after the fitment of the decat? thanks
sinex is offline   Reply With Quote
Old Nov 16th, 2008, 5:44 pm   #2 (permalink)
johnchypermotard's Avatar
which cat eliminator did you purchase? the leovince, or the termi/dp unit? the reason i ask, is that the termi unit does not fit as well as the leovince unit, and some folks have reported exhaust leaks from the termi cat eliminator. from what i have seen, the termi unit has the riser pipe (the one that connects to the rear cylinder header) a little too short, and allows exhaust to leak, even when the clamp is fully tight.
also, are you going to keep the lambda sensor plugged in, or will you eliminate it?
the basic installation is drop dead simple.
a presto,
johnc
Old Nov 16th, 2008, 11:17 pm   #3 (permalink)
sinex's Avatar
Just deciding on purchase, any got any pics of the Leo Vince cat? I guess I would keep the Landa plugged in, as I belive it's disabled by the DP chip,
CAT removal question, slip-on termis Scorchio HyperMotard 13 Sep 12th, 2008 4:57 pm
leo vince cat eliminator problem? jonvan HyperMotard 2 May 8th, 2008 8:51 pm
Mid Pipe for Termi Slipon hendricks HyperMotard 7 Mar 20th, 2008 7:42 am
Lv Cat Pipe GEE-BEE HyperMotard 6 Mar 19th, 2008 1:35 pm
Aarow header pipe - horizontal cylinder JDuc Monster 7 Oct 3rd, 2006 4:12 pm
