Nov 15th, 2008, 12:55 pm
DP ECU 2-1-2 Slip on, expert Knowledge req
Am I correct, the chip turns off the 02 Sensor, but maintains the flapper motor?
The Ducati technician, can through the software options, de-activate the flapper motor?
The fuel consumption with the DP ECU will improve?
Thanks in advance,
Nov 15th, 2008, 1:08 pm
I just installed the 308B slipon ECU today!
I also connected with VDSTS and turned off the service wrench, reset the TPS and deactivated, disconnected and removed the servo (flapper) motor.
It did throw me a kink when the new ECU displayed 3500 miles instead of 2100. Then i noticed the display was in EU so I switched it to USA and all is good.
TREADMARKS
Ford F150 4x2 Lifted
Nov 15th, 2008, 1:15 pm
VDSTS, did you use a laptop? where did you get the cable software?
Could you have just disabled the flapper motor, and left it in place?
Nov 15th, 2008, 2:30 pm
Disconnect it from the loom and take the dead weight off your bike, put it back on when you sell if you want.
Yes it will disable the 02 and flapper.
Cheers KTiMpostor
Monstaman
2010 KTM 990 SMR, 6 speed.
2004 Designa Yello DR650
Nov 15th, 2008, 2:36 pm
You can get the vdsts software at technoresearch.com.
Read this thread about the servo deactivation.
TREADMARKS
Nov 16th, 2008, 12:51 am
i checked out technoresearch.com, could you download what you needed for free or did you have to buy the $190. tool? i did not see a mac download format so i was not sure?
